Phil1978 Posted October 2, 2007 Author Report Share Posted October 2, 2007 wow you must get some speed up getting out the garage Mind you, you do have an RS4!!! (lucky b@st@rd) I did think you would wear a seatbelt Daz, just wondered if it was you disabling the alarm or if it came like that from Audi. vertigo, I'll see what I can find and post back. Link to comment Share on other sites More sharing options...
AvantSE Posted October 2, 2007 Report Share Posted October 2, 2007 Can it be enabled then (the seatbelt warning) ? My other thread suggests not, given the replies. Link to comment Share on other sites More sharing options...
Phil1978 Posted October 2, 2007 Author Report Share Posted October 2, 2007 I dont believe the B6 has the wiring in place even if you did change the coding. Have a look at the catch part next to the centre console, if it is possible there will be a seperate wire running to the housing of the catch part. If not you'll have to buy a B7 Link to comment Share on other sites More sharing options...
CactusGreen Posted October 3, 2007 Report Share Posted October 3, 2007 [ QUOTE ] I dont believe the B6 has the wiring in place even if you did change the coding. Have a look at the catch part next to the centre console, if it is possible there will be a seperate wire running to the housing of the catch part. If not you'll have to buy a B7 [/ QUOTE ] I turned the lamp on just fine in my B5, but that's all it does....light up for a short time then go out regardless of the seastbelt being used....I still like all the coloured though Link to comment Share on other sites More sharing options...
