synmaster Posted October 18, 2007 Report Share Posted October 18, 2007 So I did the front end swap on my D3 to the current s8. I used the 2005 w12 LED DRL headlamps. I have recoded control 09 and 55. Still cant get power to the headlamps. Checked the harness info on bentley publishing as well. It seems to be the same for both models Anyone have any other ideas? trying to get this car done for SEMA, thanks! here is my current VAG faults VAG-COM Version: Release 704.1 Data version: 20070723 Wednesday,17,October,2007,17:17:13:28471 Chassis Type: 4E0 Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42 46 47 4F 52 53 55 56 61 62 65 67 72 76 77 VIN: WAULL44E15N015342 Mileage: 40690km/25283miles 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: Malfunction 0010 02-Auto Trans -- Status: Malfunction 0010 03-ABS Brakes -- Status: Malfunction 0010 05-Acc/Start Auth. -- Status: Malfunction 0010 06-Seat Mem. Pass -- Status: OK 0000 07-Control Head -- Status: Malfunction 0010 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 0E-Media Player 1 -- Status: Malfunction 0010 0F-Digital Radio -- Status: Malfunction 0010 15-Airbags -- Status: Malfunction 0010 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: Malfunction 0010 25-Immobilizer -- Status: Malfunction 0010 34-Level Control -- Status: Sporadic communication error 1000 36-Seat Mem. Drvr -- Status: OK 0000 37-Navigation -- Status: Malfunction 0010 38-Roof Electronics -- Status: Malfunction 0010 42-Door Elect, Driver -- Status: Malfunction 0010 46-Central Conv. -- Status: Malfunction 0010 47-Sound System -- Status: OK 0000 4F-Centr. Electr. II -- Status: Malfunction 0010 52-Door Elect, Pass. -- Status: Malfunction 0010 53-Parking Brake -- Status: OK 0000 55-Xenon Range -- Status: Malfunction 0010 56-Radio -- Status: OK 0000 61-Battery Regul. -- Status: Malfunction 0010 62-Door,Rear Left -- Status: Malfunction 0010 65-Tire Pressure -- Status: Malfunction 0010 67-Voice Control -- Status: OK 0000 72-Door, Rear Right -- Status: Malfunction 1010 76-Park Assist -- Status: Malfunction 0010 77-Telephone -- Status: Cannot be reached 1100 ------------------------------------------------------------------------------- Address 01: Engine Labels: None Part No SW: 4E0 910 560 J HW: 4E0 907 560 Component: 4.2L V8/5V G 0010 Coding: 0007773 Shop #: WSC 02313 2 Faults Found: 18061 - Please check DTC Memory of ABS Controller P1653 - 008 - Implausible Signal - Intermittent 18010 - Power Supply Terminal 30: Voltage too Low P1602 - 002 - Lower Limit Exceeded - Intermittent Readiness: 0010 0101 ------------------------------------------------------------------------------- Address 02: Auto Trans Labels: None Part No SW: 4E0 910 156 S HW: 09E 927 156 A Component: AG6 09E 4,2L5V USA 0020 Coding: 0000002 Shop #: WSC 02313 1 Fault Found: 18005 - Powertrain Databus: Missing Message from Level Control System (J197) P1597 - 000 - - - Intermittent Freeze Frame: Fault Status: 00110000 Fault Priority: 0 Fault Frequency: 1 Reset counter: 39 Mileage: 40692 km Time Indication: 0 Date: 2004.04.19 Time: 02:13:16 Freeze Frame: RPM: 1696 /min RPM: 1536 /min RPM: 0 /min (no units): 30.0 (no units): 25.0 Temperature: 19.0°C T.B . Angle: 0.0° ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 4E0-910-517.LBL Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC Component: ESP 5.7 allrad H44 0510 Coding: 0008597 Shop #: WSC 02313 2 Faults Found: 01542 - Yaw Rate Sensor (G202) 008 - Implausible Signal - Intermittent 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 000 - - - Intermittent ------------------------------------------------------------------------------- Address 05: Acc/Start Auth. Labels: None Part No SW: 4E0 910 131 HW: 4E0 909 131 D Component: FBS AUDID3 H04 0140 Coding: 0410624 Shop #: WSC 02311 Part No: XXXXXXXXXXX Component: ELV XXXX 4 Faults Found: 01334 - Door Control Module; Rear Right (J398) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.06.23 Time: 11:55:00 00180 - Access/Start Authorization Antenna; Passenger Side (R135) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 204 Mileage: 40688 km Time Indication: 0 Date: 2004.03.25 Time: 02:22:54 00181 - Access/Start Authorization Antenna (in Rear bumper) (R136) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 202 Mileage: 40688 km Time Indication: 0 Date: 2004.03.25 Time: 02:22:54 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 4 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.04.16 Time: 21:14:20 ------------------------------------------------------------------------------- Address 06: Seat Mem. Pass Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory BFS H08 0060 Coding: 3940448 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 07: Control Head Labels: 4E0-910-7xx-07.LBL Part No SW: 4E0 910 730 G HW: 4E0 035 729 Component: Interfacebox H43 1070 Coding: 0000003 Shop #: WSC 02313 Part No: 4E0 910 609 C Component: Bedienteil MMI H42 0100 1 Fault Found: 01310 - Level Control System Control Module (J197) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 1 Reset counter: 205 Mileage: 40692 km Time Indication: 0 Date: 2004.04.19 Time: 02:14:07 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: None Part No SW: 4E0 910 043 B HW: 4E0 820 043 C Component: KLIMAAUTOMAT 016 0400 Coding: 1052993 Shop #: WSC 02311 No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 4E0-910-279.LBL Part No SW: 4E0 910 279 L HW: 4E0 907 279 L Component: ILM Fahrer H12 0210 Coding: 0133121 Shop #: WSC 02313 Part No: 4E1 910 113 B Component: Wischer WWS D3 H50 0400 Coding: 00000035 Shop #: WSC 02313 Part No: 4E0 910 557 Component: REGENLICHTSENSORH10 0050 Coding: 00139548 Shop #: WSC 02313 5 Faults Found: 00908 - Control Module for Wiper Motor 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 1 Fault Frequency: 2 Reset counter: 202 Mileage: 0 km Time Indication: 0 01494 - Bulb for Parking Lamps; Left (M1) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 40693 km Time Indication: 0 Date: 2004.04.23 Time: 03:45:24 01498 - Bulb for Parking Lamps; Right (M3) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 40693 km Time Indication: 0 Date: 2004.04.23 Time: 03:45:24 01496 - Bulb for Fog-Lamps; Left (L22) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 40693 km Time Indication: 0 Date: 2004.04.23 Time: 03:45:24 01500 - Bulb for Fog-Lamps; Right (L23) 010 - Open or Short to Plus Freeze Frame: Fault Status: 01101010 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 40693 km Time Indication: 0 Date: 2004.04.23 Time: 03:45:25 ------------------------------------------------------------------------------- Address 0E: Media Player 1 Labels: 4E0-910-111.LBL Part No SW: 4E0 910 111 E HW: 4E0 035 111 A Component: CD-Changer H44 0430 1 Fault Found: 02095 - Component Protection Active 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 4 Fault Frequency: 1 Reset counter: 183 Mileage: 40628 km Time Indication: 0 Date: 2004.04.02 Time: 16:54:12 ------------------------------------------------------------------------------- Address 0F: Digital Radio Labels: 4E0-910-593-XM.LBL Part No SW: 4E0 910 593 E HW: 4E0 035 593 A Component: 1 Fault Found: 02635 - Tuner Not Enabled/Activated 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 7 Fault Frequency: 2 Reset counter: 204 Mileage: 40692 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:02 ------------------------------------------------------------------------------- Address 15: Airbags Labels: 4E0-910-655-84.LBL Part No SW: 4E0 910 655 A HW: 4E0 959 655 E Component: Airbag 8.4E+ H10 0920 Coding: 0530707 Shop #: WSC 02313 2 Faults Found: 01219 - Rear Airbag Igniter; Driver Side (N201) 001 - Upper Limit Exceeded - Intermittent - MIL ON 01639 - Crash-Sensor for Side Airbag; Rear Passenger Side (G257) 011 - Open Circuit - Intermittent ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 4E0-910-549.LBL Part No SW: 4E0 910 549 HW: 4E0 953 549 Component: Lenksäulenmodul H13 0040 Coding: 0012141 Shop #: WSC 02311 Part No: XXXXXXXXXXX Component: Lenkradmodul H05 0080 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 4E0-910-xxx-17.LBL Part No SW: 4E0 910 950 G HW: 4E0 920 950 G Component: KOMBIINSTR. VDO H53 0210 Coding: 0016233 Shop #: WSC 22133 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: None Part No SW: 4E0 910 468 B HW: 4E0 907 468 E Component: Gateway H10 0080 Coding: FCFE7BDD1B7904 Shop #: WSC 02313 4 Faults Found: 00470 - Combination comfort Databus in Single Wire 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 197 Mileage: 40689 km Time Indication: 0 Date: 2004.06.23 Time: 11:53:23 01334 - Door Control Module; Rear Right (J398) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 197 Mileage: 40689 km Time Indication: 0 Date: 2004.06.23 Time: 11:54:58 01303 - Telephone Transceiver (R36) 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 6 Reset counter: 166 Mileage: 40690 km Time Indication: 0 Date: 2004.03.26 Time: 00:43:41 01310 - Level Control System Control Module (J197) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 205 Mileage: 40692 km Time Indication: 0 Date: 2004.04.19 Time: 02:13:16 ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: None Part No SW: 4E0 910 131 HW: 4E0 909 131 D Component: FBS AUDID3 H04 0140 Coding: 0410624 Shop #: WSC 02311 Part No: XXXXXXXXXXX Component: ELV XXXX XXXXXXXXXXX ELV XXXX 4 Faults Found: 01334 - Door Control Module; Rear Right (J398) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.06.23 Time: 11:55:00 00180 - Access/Start Authorization Antenna; Passenger Side (R135) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 204 Mileage: 40688 km Time Indication: 0 Date: 2004.03.25 Time: 02:22:54 00181 - Access/Start Authorization Antenna (in Rear bumper) (R136) 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 4 Fault Frequency: 0 Reset counter: 202 Mileage: 40688 km Time Indication: 0 Date: 2004.03.25 Time: 02:22:54 00668 - Supply Voltage Terminal 30 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 2 Fault Frequency: 4 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.04.16 Time: 21:14:20 ------------------------------------------------------------------------------- Address 34: Level Control Labels: 4E0-910-553.LBL Part No SW: 4E0 910 553 J HW: 4E0 907 553 F Component: LUFTFDR.-CDC H06 6310 Coding: 0015510 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 36: Seat Mem. Drvr Labels: None Part No SW: 4E0 910 760 C HW: 4E0 959 760 Component: Sitzmemory FS H08 0060 Coding: 4071530 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4E0-910-88x-37.LBL Part No SW: 4E0 910 888 C HW: 4E0 919 887 C Component: MNS US H44 0960 3 Faults Found: 02261 - Media Player; Position 1 (R118) 014 - Defective - Intermittent Freeze Frame: Fault Status: 00101110 Fault Priority: 7 Fault Frequency: 2 Reset counter: 201 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 23:40:25 Freeze Frame: Hex Value: 0x4072 Hex Value: 0x16E2 Hex Value: 0xFA10 Hex Value: 0xF000 03183 - Unknown Error Code 000 - - Freeze Frame: Fault Status: 01100000 Fault Priority: 6 Fault Frequency: 27 Reset counter: 166 Mileage: 40626 km Time Indication: 0 Date: 2004.04.02 Time: 16:08:34 Freeze Frame: Hex Value: 0x4088 Hex Value: 0x9191 Hex Value: 0x0303 02927 - DVD Read Error 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 6 Fault Frequency: 3 Reset counter: 204 Mileage: 40690 km Time Indication: 0 Date: 2004.04.05 Time: 23:02:21 Freeze Frame: Hex Value: 0x407C Hex Value: 0xD307 ------------------------------------------------------------------------------- Address 38: Roof Electronics Labels: 4E0-910-135.LBL Part No SW: 4E0 910 135 A HW: 4E0 907 135 Component: Dachknoten D3 H02 0090 Coding: 0003477 Shop #: WSC 02313 1 Fault Found: 01334 - Door Control Module; Rear Right (J398) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 0 Fault Frequency: 15 Reset counter: 205 Mileage: 40692 km Time Indication: 0 Date: 2004.03.25 Time: 00:00:00 ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: None Part No SW: 4E1 910 802 B HW: 4E1 959 801 B Component: Türsteuer.FS BRM002 0060 Coding: 0028204 Shop #: WSC 02311 1 Fault Found: 01334 - Door Control Module; Rear Right (J398) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.06.23 Time: 11:55:12 ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 4E0-910-289.LBL Part No SW: 4E0 910 289 A HW: 4E0 907 289 Component: Komfortgeraet H04 0040 Coding: 0065086 Shop #: WSC 02313 Part No: 4E0 910 853 Component: Heckdeckel H06 0060 Part No: 4E0 907 719 Component: Neigungssensor H03 0020 2 Faults Found: 01334 - Door Control Module; Rear Right (J398) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 5 Fault Frequency: 254 Reset counter: 205 Mileage: 40689 km Time Indication: 0 Date: 2004.06.23 Time: 11:55:04 01504 - Bulb for License-Plate Light (X) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 254 Reset counter: 166 Mileage: 15739 km Time Indication: 0 Date: 2006.01.10 Time: 12:59:40 ------------------------------------------------------------------------------- Address 47: Sound System Labels: 4E0-910-223.LBL Part No SW: 4E0 910 223 K HW: 4E0 035 223 A Component: DSP-Amp.-High H13 0440 Coding: 0000016 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 4F: Centr. Electr. II Labels: None Part No SW: 4E0 910 280 A HW: 4E0 907 280 A Component: ILM Beifahrer H09 0040 Coding: 0010111 Shop #: WSC 02313 1 Fault Found: 02258 - Door Opener Transmitter 004 - No Signal/Communication Freeze Frame: Fault Status: 01100100 Fault Priority: 3 Fault Frequency: 86 Reset counter: 166 Mileage: 40688 km Time Indication: 0 Date: 2004.03.25 Time: 02:21:00 ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: None Part No SW: 4E1 910 802 B HW: 4E1 959 802 B Component: Türsteuer.BF BRM002 0060 Coding: 0028204 Shop #: WSC 02311 1 Fault Found: 01334 - Door Control Module; Rear Right (J398) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.06.23 Time: 11:55:12 ------------------------------------------------------------------------------- Address 53: Parking Brake Labels: None Part No SW: 4E0 910 801 A HW: 4E0 907 801 Component: EPB AV1C1010 H01 1010 Coding: 0000532 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 55: Xenon Range Labels: None Part No SW: 4E0 910 357 HW: 4E0 907 357 Component: Pre-AFS H01 0040 Coding: 0000004 Shop #: WSC 02311 3 Faults Found: 01539 - Headlights Not Adjusted 005 - No or Incorrect Basic Setting / Adaptation - MIL ON Freeze Frame: Fault Status: 11100101 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 40696 km Time Indication: 0 Date: 2004.04.23 Time: 03:31:09 02233 - Left Headlight Power Output Stage (J667) 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 40696 km Time Indication: 0 Date: 2004.04.23 Time: 03:31:09 02234 - Right Headlight Power Output Stage (J668) 004 - No Signal/Communication - MIL ON Freeze Frame: Fault Status: 11100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 166 Mileage: 40696 km Time Indication: 0 Date: 2004.04.23 Time: 03:31:09 ------------------------------------------------------------------------------- Address 56: Radio Labels: 4E0-910-541.LBL Part No SW: 4E0 910 541 F HW: 4E0 035 541 E Component: TUNER EU/US/RDW H42 0480 Coding: 0000002 Shop #: WSC 02313 No fault code found. ------------------------------------------------------------------------------- Address 61: Battery Regul. Labels: 4E0-910-181.LBL Part No SW: 4E0 910 181 C HW: 4E0 915 181 C Component: J0644 BEM H12 0510 Part No: 4E0 915 105 A Component: von VA0 1502140363 Coding: 344530393135313035412056413031353032313430333633 Shop #: WSC 00000 4 Faults Found: 02273 - Rest Current Stage 2 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 53 Mileage: 39390 km Time Indication: 0 Date: 2004.03.25 Time: 00:18:45 02276 - Rest Current Stage 5 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 50 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 04:28:12 02274 - Rest Current Stage 3 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 50 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 04:28:22 02277 - Rest Current Stage 6 000 - - - Intermittent Freeze Frame: Fault Status: 00100000 Fault Priority: 7 Fault Frequency: 47 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 04:28:32 ------------------------------------------------------------------------------- Address 62: Door,Rear Left Labels: 4E0-910-802.LBL Part No SW: 4E0 910 802 A HW: 4E0 959 801 C Component: Türsteuer.HL BRM002 0060 Coding: 0028204 Shop #: WSC 02311 1 Fault Found: 01334 - Door Control Module; Rear Right (J398) 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 4 Fault Frequency: 0 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.06.23 Time: 11:55:12 ------------------------------------------------------------------------------- Address 65: Tire Pressure Labels: 4E0-910-273.LBL Part No SW: 4E0 910 273 HW: 4E0 907 273 Component: Reifendruck 2 H01 0280 Coding: 0232125 Shop #: WSC 22133 1 Fault Found: 00003 - Control Module 000 - - - MIL ON Freeze Frame: Fault Status: 11100000 Fault Priority: 2 Fault Frequency: 1 Mileage: 29807 km Time Indication: 0 Date: 2006.08.31 Time: 13:57:37 Freeze Frame: Speed: 0.0 km/h Voltage: 13.30 V (no units): 11.0 Not Recogn. Not Recogn. Not Recogn. Not Recogn. ------------------------------------------------------------------------------- Address 67: Voice Control Labels: 4E0-910-75x-67.LBL Part No SW: 4E0 910 753 S HW: 4E0 035 753 A Component: SDS 3501 US H45 0550 No fault code found. ------------------------------------------------------------------------------- Address 72: Door, Rear Right Labels: 4E0-910-802.LBL Part No SW: 4E0 910 802 A HW: 4E0 959 802 C Component: Türsteuer.HR BRM002 0060 Coding: 0028204 Shop #: WSC 02311 5 Faults Found: 00470 - Combination comfort Databus in Single Wire 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 0 Reset counter: 197 Mileage: 40688 km Time Indication: 0 Date: 2004.06.23 Time: 11:53:44 01482 - Motors for Central Locking 007 - Short to Ground - Intermittent Freeze Frame: Fault Status: 00100111 Fault Priority: 2 Fault Frequency: 0 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.04.17 Time: 04:38:18 02130 - Interior Door Lighting 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 14 Reset counter: 166 Mileage: 40688 km Time Indication: 0 Date: 2004.04.17 Time: 04:46:54 02127 - Exterior Door Handle Light / Mirror Light 012 - Electrical Fault in Circuit Freeze Frame: Fault Status: 01101100 Fault Priority: 3 Fault Frequency: 14 Reset counter: 166 Mileage: 40688 km Time Indication: 0 Date: 2004.04.17 Time: 04:49:32 00379 - Terminal 58s 012 - Electrical Fault in Circuit - Intermittent Freeze Frame: Fault Status: 00101100 Fault Priority: 3 Fault Frequency: 0 Reset counter: 205 Mileage: 40688 km Time Indication: 0 Date: 2004.04.19 Time: 02:14:10 ------------------------------------------------------------------------------- Address 76: Park Assist Labels: 4E0-910-283.LBL Part No SW: 4E0 910 283 A HW: 4E0 919 283 B Component: Parkhilfe 8-Kan H12 0020 Coding: 0001208 Shop #: WSC 02313 5 Faults Found: 01626 - Sensor for Parking-Aid; Front Right (G252) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 165 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 04:41:33 01628 - Sensor for Parking-Aid; Front Mid-Left (G254) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 165 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 04:41:33 01627 - Sensor for Parking-Aid; Front Mid-Right (G253) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 2 Reset counter: 165 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 04:41:33 02070 - Rear Parking Aid Sensors 011 - Open Circuit - Intermittent Freeze Frame: Fault Status: 00101011 Fault Priority: 3 Fault Frequency: 1 Reset counter: 204 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 02:22:25 02069 - Front Parking Aid Sensors 011 - Open Circuit Freeze Frame: Fault Status: 01101011 Fault Priority: 3 Fault Frequency: 2 Reset counter: 165 Mileage: 40690 km Time Indication: 0 Date: 2004.03.25 Time: 02:22:25 ------------------------------------------------------------------------------- Address 77: Telephone Labels: 4E0-910-336.LBL Part No SW: 4F0 910 336 A HW: 4E0 862 335 Component: Handyvorb2 H10 0120 Coding: 0010900 Shop #: WSC 02313 1 Fault Found: 00532 - Supply Voltage B+ 002 - Lower Limit Exceeded - Intermittent Freeze Frame: Fault Status: 00100010 Fault Priority: 7 Fault Frequency: 1 Reset counter: 202 Mileage: 40692 km Time Indication: 0 Date: 2004.03.29 Time: 02:23:07 End -------------------------------------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
