MATR32 Posted November 16, 2007 Report Share Posted November 16, 2007 got in to the car earlier and it would not start and the trans light was flashing and the tranction control light was on and i could not turn it off. did get it started but these are the codes 00-Steering Angle Sensor -- Status: OK 0000 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: Malfunction 0010 08-Auto HVAC -- Status: Malfunction 0010 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door,Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 76-Park Assist -- Status: OK 0000 -------------------------------------------------------------------------------Address 01: Engine Labels: 06F-907-115-AXX.LBL Part No SW: 1K0 907 115 T HW: 8P0 907 115 B Component: 2.0l R4/4V TFSI 0010 Coding: 0403000318070060 Shop #: WSC 01279 No fault code found. Readiness: 0000 0000 -------------------------------------------------------------------------------Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.LBL Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Coding: 0004738 Shop #: WSC 01279 1 Fault Found: 01315 - Transmission Control Module 004 - No Signal/Communication - Intermittent ------------------------------------------------------------------------------- VAG-COM Self-Diagnosis Log Friday,16,November,2007,22:12:27:13472 Page 2 Address 08: Auto HVAC Labels: 1K0-907-044.LBL Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS Component: ClimatronicPQ35 120 1111 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent -------------------------------------------------------------------------------Address 09: Cent. Elect. Labels: 3C0-937-049.LBL Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Coding: E58D8F2700041500471400001400000000087F075C000100000000000000 Shop #: WSC 01367 Part No: 1K2 955 119 E Component: Wischer 070607 021 0501 Coding: 00038805 Shop #: WSC 01367 Part No: 1K0 955 559 AF Component: RLS 140607 046 0204 Coding: 00208933 Shop #: WSC 01367 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Fault Status: 00100100 Fault Priority: 2 Fault Frequency: 1 Reset counter: 192 Mileage: 4404 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 12.15 V ON ON OFF OFF OFF ------------------------------------------------------------------------------- VAG-COM Self-Diagnosis Log Friday,16,November,2007,22:12:27:13472 Page 3 Address 15: Airbags Labels: 1K0-909-605.LBL Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: 38 AIRBAG VW8 020 2300 Coding: 0013112 Shop #: WSC 01269 No fault code found. -------------------------------------------------------------------------------Address 16: Steering wheel Labels: 1K0-953-549.LBL Part No SW: 1K0 953 549 BC HW: 1K0 953 549 BC Component: Lenksäulenmodul 036 0070 Coding: 0000012 Shop #: WSC 01279 No fault code found. -------------------------------------------------------------------------------Address 17: Instruments Labels: 1K0-920-xxx-17.LBL Part No SW: 1K6 920 964 HW: 1K6 920 964 Component: KOMBIINSTRUMENT VDD 1214 Coding: 0003403 Shop #: WSC 00322 No fault code found. -------------------------------------------------------------------------------Address 19: CAN Gateway Labels: 1K0-907-530.LBL Part No SW: 1K0 907 530 K HW: 1K0 907 951 Component: J533__Gateway H04 0021 Coding: 3D3F074007000003 Shop #: WSC 01279 No fault code found. -------------------------------------------------------------------------------Address 25: Immobilizer Labels: 1K0-920-xxx-25.LBL Part No SW: 1K6 920 964 HW: 1K6 920 964 Component: IMMO VDD 1214 No fault code found. -------------------------------------------------------------------------------Address 42: Door Elect, Driver Labels: 1K0-959-701-MAX3.LBL Part No SW: 1K0 959 701 N HW: 1K0 959 701 N Component: Tuer-SG 006 120B Coding: 0000692 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- VAG-COM Self-Diagnosis Log Friday,16,November,2007,22:12:27:13472 Page 4 Address 44: Steering Assist Labels: 1Kx-909-14x.LBL Part No: 1K2 909 144 M Component: EPS_ZFLS Kl.074 H08 1901 1 Fault Found: 01314 - Engine Control Module 004 - No Signal/Communication - Intermittent Freeze Frame: Mileage: 4400 km Temperature: 29.0°C Voltage: 12.20 V Voltage: 12.00 V -------------------------------------------------------------------------------Address 46: Central Conv. Labels: 1K0-959-433-46.LBL Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Coding: 819002005103087F2D0484057008DFC690FCA0 Shop #: WSC 01367 Part No: 1K0 951 605 D Component: LIN BACKUP HORN H07 9001 Part No: 1K0 951 178 A Component: Neigungssensor 003 0203 Part No: 1K0 951 178 A Component: Innenraumueberw.003 0203 No fault code found. -------------------------------------------------------------------------------Address 52: Door Elect, Pass. Labels: 1K0-959-702-MAX3.LBL Part No SW: 1K0 959 702 N HW: 1K0 959 702 N Component: Tuer-SG 006 120B Coding: 0000948 Shop #: WSC 01279 No fault code found. -------------------------------------------------------------------------------Address 56: Radio Labels: 1K0-035-1xx-56.LBL Part No SW: 1K0 035 186 AD HW: 1K0 035 186 AD Component: Radio BVX 034 0046 Coding: 0040400 Shop #: WSC 01279 No fault code found. ------------------------------------------------------------------------------- VAG-COM Self-Diagnosis Log Friday,16,November,2007,22:12:27:13472 Page 5 Address 62: Door,Rear Left Labels: 1K0-959-703-GEN3.LBL Part No SW: 1K0 959 703 K HW: 1K0 959 703 K Component: Tuer-SG 006 1202 Coding: 0000144 Shop #: WSC 01279 No fault code found. -------------------------------------------------------------------------------Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.LBL Part No SW: 1K0 959 704 K HW: 1K0 959 704 K Component: Tuer-SG 006 1201 Coding: 0000144 Shop #: WSC 01279 No fault code found. -------------------------------------------------------------------------------Address 76: Park Assist Labels: 1K0-919-283.LBL Part No: 1K0 919 283 A Component: 22 Einparkhilfe 0101 No fault code found. End --------------------------------------------------------------------------------- Link to comment Share on other sites More sharing options...
Sebastian Posted November 17, 2007 Report Share Posted November 17, 2007 Can't see much wrong in that scan besides it being pretty messed up in terms formatting. In future you may want to use the copy paste function instead of copying from a print. However, there are some communication errors but nothing obvious that should cause a no-start. Could you give us some more background? Any mods, recent issues etc.? Link to comment Share on other sites More sharing options...
MATR32 Posted November 17, 2007 Author Report Share Posted November 17, 2007 all sorted now Link to comment Share on other sites More sharing options...
Decked Posted November 23, 2007 Report Share Posted November 23, 2007 What was it? Link to comment Share on other sites More sharing options...
