vwturbo Posted November 18, 2007 Report Share Posted November 18, 2007 got problem with drivers wiper on pasat s 1.8t 2001 model,they are the blade type,passaengers side is fine,drivers side is crap,it doesnt seem to sit proply Link to comment Share on other sites More sharing options...
meriafel Posted November 19, 2007 Report Share Posted November 19, 2007 Make sure the arm, when lifted, is smooth in operation with no friction which can substantially lessen the pressure the spring applies in pressing the blade onto the screen. Apply any lubricant very sparingly. Lifting the arms often will free them off. They can become quite stiff with corrosion as they move only by a few degrees. Also make sure the blades are at 90 degrees to the screen surface. They end of the arm does seem to bend after a long period of use and needs to be bent back to sit 'flat' on the screen surface. Take care the arm doesn't slip from your grasp and bang the screen as it can break it! Link to comment Share on other sites More sharing options...
gypsyboy Posted November 23, 2007 Report Share Posted November 23, 2007 hello i had a problem with blades and thought they were not sitting right because they did not wipe that great i changed them and great. Link to comment Share on other sites More sharing options...
vwturbo Posted December 11, 2007 Author Report Share Posted December 11, 2007 ive changed mine,passenger side is great,drivers side is terrible,wont wipe clear Link to comment Share on other sites More sharing options...
Smiddy Posted April 9, 2008 Report Share Posted April 9, 2008 Iv got the same problem on my 03 Passat, I put on new wipers and it made no difference, Iv got new wiper arm on order this week, I'll let you know if that sorts it. Link to comment Share on other sites More sharing options...
