safety69 Posted December 22, 2007 Report Share Posted December 22, 2007 Hello, I have an 1997 Audi A3 1.6 engine code AEH, and its developed a strange problem which i shall try and explain. Not all the time but at junctions, when i go to pull away with clutch on biting point i add a little gas, the engine goes to stall, so i quickly dip the clutch to prevent it from doing so. The responsiveness of the accelerator is poor. I have carried out the following procedures as listed. 1) Cleaned throttle body, reset with Vag-Com, idles between 800-900 rpm which i've been told is fine. 2) Tried a fuel injection cleaner. 3) A vag-com check and no fault codes. Whilst i was cleaning my throttle body i saw a tiny electronic element with a wire in the inlet manifold and not sure what this is, and maybe could be something to do with my problem. Please can anyone shine some light, Thanks Link to comment Share on other sites More sharing options...
PetrolDave Posted December 23, 2007 Report Share Posted December 23, 2007 [ QUOTE ] Whilst i was cleaning my throttle body i saw a tiny electronic element with a wire in the inlet manifold and not sure what this is, and maybe could be something to do with my problem. [/ QUOTE ] That's the MAT (Manifold Air Temperature) sensor. Link to comment Share on other sites More sharing options...
safety69 Posted December 23, 2007 Author Report Share Posted December 23, 2007 Thanks Dave. I found alot of oil on the sensor, could this cause damage to the sensor and cause the problem i'm currently experiencing? Link to comment Share on other sites More sharing options...
TDiAvant Posted December 24, 2007 Report Share Posted December 24, 2007 This could be a MAF fault, I had similar problem on my A4. Replaced the MAF and all was well. Never showed up any fault codes. Link to comment Share on other sites More sharing options...
safety69 Posted December 25, 2007 Author Report Share Posted December 25, 2007 Sorry, forgot to mention i have also replaced the MAF unit, and still the problem remains. I have full access to vag-com, but not too sure how to check certain sensors and what figures to compare against. My suspicions are, that maybe the throttlebody needs replacing, or maybe the MAT sensor? I'm sure it has to be something directly involved with the throttle for the problem i'm experiencing, or am i wrong in thinking this. I find with trouble shooting its trial and error which can leave a dent in your wallet!! Link to comment Share on other sites More sharing options...
safety69 Posted December 25, 2007 Author Report Share Posted December 25, 2007 I found numerous bits of info regarding the same problem i'm encountering, and created a checklist below of what i have narrowed it down to. 1) Cleaned TB and also realigned using Vag-Com, need replacing? 2)Replaced MAF unit. 3)MAT sensor still to check 4)Coolant sensor still to check. Link to comment Share on other sites More sharing options...
harshy09 Posted April 20, 2009 Report Share Posted April 20, 2009 i had the same problem, then finally the engine management warning light came on which helped diagnose the problem its was a sensor sensor 1 senser bank 1 which was the oxygen/lambda Link to comment Share on other sites More sharing options...
BW2309 Posted May 4, 2009 Report Share Posted May 4, 2009 Check fuel pressure and it's regulator. Should have a 3BAR fuel press' reg'. These can fail or the pressure drop over time. Also check the plugs! Number 3 plug is difficult to get to and I've seen many that have not had it changed, even at the dealers!!!! If it's got a really old plug it wont be healping. Most likely cause in my opinion is that there's an air leak. Check all breather pipes and vacuum feeds. Also, check that the plastic inlet manifold has not cracked - they do and they're a lot of money!!! You can get a spray from most places such as Halfords that if you spray over inlet and pipe work they engine will slow if it is able to breath the stuff in. This causes no damage and will direct you to the leak. Good luck! Link to comment Share on other sites More sharing options...
Shorty Posted June 2, 2009 Report Share Posted June 2, 2009 Hello, I have an 1997 Audi A3 1.6 engine code AEH, and its developed a strange problem which i shall try and explain. Not all the time but at junctions, when i go to pull away with clutch on biting point i add a little gas, the engine goes to stall, so i quickly dip the clutch to prevent it from doing so. The responsiveness of the accelerator is poor. I have carried out the following procedures as listed.1) Cleaned throttle body, reset with Vag-Com, idles between 800-900 rpm which i've been told is fine. 2) Tried a fuel injection cleaner. 3) A vag-com check and no fault codes. Whilst i was cleaning my throttle body i saw a tiny electronic element with a wire in the inlet manifold and not sure what this is, and maybe could be something to do with my problem. Please can anyone shine some light, Thanks this sounds exactly the same problem i was having, couldn't find a reason why took to 3 different garages and said sounds like air mass meter after having it connected to a computer, had it changed few weeks later started again. eventually car just died 130 miles away from home, AA engineer had a look and the cambelt tensioner had broken, he said this was a common fault with these as he used to work for VW and is more than likely the reason why the engine was stalling. repair was done and hasn't stalled once.hope this helps Link to comment Share on other sites More sharing options...
