mrkipper Posted January 1, 2008 Report Share Posted January 1, 2008 Hello happy 08 to all, New year new problem that I seem to have with the passenger window.It goes down ok but wont go up.It starts to then stops and automaticaly goes back down.Thought it maybe the switch, but its the same when controlling it from the divers side.Any ideas what could be wrong? Thanks Link to comment Share on other sites More sharing options...
kite Posted January 1, 2008 Report Share Posted January 1, 2008 Try a bit of WD40, the window motor is sensing a bit of sticking. Link to comment Share on other sites More sharing options...
davox Posted January 1, 2008 Report Share Posted January 1, 2008 It could be that you have a broken window clip. The clip attaches the window glass to the wire driven by the electric motor. I had this problem with my 98 A3 with similar symptoms to you. I think they redesigned the clip on newer cars se may not be relevant to you. Take a look here : http://www.tyresmoke.net/ubbthreads/show...true#Post354708 Link to comment Share on other sites More sharing options...
mrkipper Posted January 2, 2008 Author Report Share Posted January 2, 2008 Hello, Thanks for the replys I had the door panel of today could'nt really see any thing wrong.Didnt have any wd40 available to give it a spray up.In any case were would be the best place to spray it around?.I had to force the window up from the bottom with my hand while inching it up from the switch.It didnt like that and just wanted to automatically go back down.At certain times i could hear just a click comming from the motor while operating the switch.The car is a late 2000 model Link to comment Share on other sites More sharing options...
kite Posted January 2, 2008 Report Share Posted January 2, 2008 spray on the window runner. the motor may be sensing a block and winding down. you can try this in a window that works, wind down the window,put your hand in the top of the frame and wind the window up, when the glass gets to your hand it will sense the block and wind down. Link to comment Share on other sites More sharing options...
prt57 Posted January 2, 2008 Report Share Posted January 2, 2008 If you have the door casing off it should be easy to see the clips mentioned above. Early ones on VW cars were plastic and can snap causing the window to drop into the door. Later ones are made of metal. Scroll through this guide of fixing a VW Bora to see the plastic and matal clips.http://forums.vwvortex.com/zerothread?id=1015107 Cheers prt Link to comment Share on other sites More sharing options...
mrkipper Posted January 3, 2008 Author Report Share Posted January 3, 2008 Thanks chaps, I will have another go at the weekend.I did see the clips they looked alright but darkness was setting in and i called it a day.Passengers dont help either the amount of times ive told them off for slamming the door, its on their side in which case the window doesent get used as much of mine!!! Link to comment Share on other sites More sharing options...
marc123 Posted January 5, 2008 Report Share Posted January 5, 2008 just chance!unplug the battery for 10 mins then give a go? Link to comment Share on other sites More sharing options...
podgorny Posted May 18, 2008 Report Share Posted May 18, 2008 Hi there, my A6 has just started doing exactly the same as described above. I'd be interested to know how you solved this. Most posts seem to suggest the clips or the motor. Mine has started playing up in the space of a week!! Any advice would be appreciated Link to comment Share on other sites More sharing options...
s3geezer Posted May 18, 2008 Report Share Posted May 18, 2008 I had this on my S3. Both windows went. The windows go down but not up. Well, they start to but the sensor kicks in and sends it down again. I needed two new "Guides". I can get the part number if anyone wants it. They cost about £8 for the pair from Audi. Link to comment Share on other sites More sharing options...
MACH1 Posted May 19, 2008 Report Share Posted May 19, 2008 Spray any lub oil, ie WD40 on the window rubbers both sides and along the bottom, this should solve the problem,, I had the same on my A6, the window anti crush system kicks in if the window is struggling to raise, and then the window automatically opens. hope this works for you. Link to comment Share on other sites More sharing options...
Jo308 Posted May 19, 2008 Report Share Posted May 19, 2008 Not sure WD40 is a good idea on rubber. You can get a spray can of rubber lube from halfords which might be safer. Link to comment Share on other sites More sharing options...
podgorny Posted May 20, 2008 Report Share Posted May 20, 2008 Yeah that sounds like a good idea to me. I always take the path of least resistance with stuff like this, rather than tearing the door apart. Luckily, the car park I have to swipe into at work has enough room between the barrier and swipe machine that I can pull forward, put my rear window down and reach out. Albeit, looking like a plonker!! I will publish my findings. Link to comment Share on other sites More sharing options...
PetrolDave Posted May 20, 2008 Report Share Posted May 20, 2008 Not sure WD40 is a good idea on rubber. Second that - you need a silicone based rubber lubricant spray. Link to comment Share on other sites More sharing options...
mrkipper Posted May 25, 2008 Author Report Share Posted May 25, 2008 Hello All, Anyone manage to sort out their window problem.I have put up with not using it, but have been told It could be a seized window regulator.Hopefully going to take the panel off again and give it a good sray up with silicon spray.Not to hopeful through Link to comment Share on other sites More sharing options...
