smizit Posted January 9, 2008 Report Share Posted January 9, 2008 I recently had the tyre sensor come on - I filled up air on all four tyres (17" Monzas with Conti) to 33psi which just felt way too hard to the point I was paranoid about popping them (I'm not a very techy person plus the Mrs normally driving it is T-2wks with baby and moaned about the bumpy ride!!) Reducing the pressure to 32psi feels fine. I wanted to know what you guys are all inflating to? Also what would you fill up to on 18" Monzas with Dunlop? Since I have them garaged for winter and use my scratched 17s at the moment... cheers smizit Link to comment Share on other sites More sharing options...
JonC Posted January 9, 2008 Report Share Posted January 9, 2008 [ QUOTE ] (edit) Also what would you fill up to on 18" Monzas with Dunlop? Since I have them garaged for winter and use my scratched 17s at the moment... [/ QUOTE ] 18 Monza II's with Continental Sports: 2.4 bar or 34psi Link to comment Share on other sites More sharing options...
JonnyGTi Posted January 9, 2008 Report Share Posted January 9, 2008 I use 32PSI for the fronts and 30PSI at the back for normal driving (no luggage, rear people etc). I know this is below whats' recommended but I've found they feel too hard otherwise, like you. If going on a long motorway journey I top them up a bit to around 33PSI all round. Link to comment Share on other sites More sharing options...
Metalex Posted January 10, 2008 Report Share Posted January 10, 2008 I tend to slightly over-inflate mine. 2.4 bar / 35 PSI is the recommended pressure according to the sticker on the inside of the fuel-flap. As the pressure drops over time, I tend to inflate to 36/37 PSI or 2.5 bar. If I've been lazy and let my pressures drop to 32/33 PSI, I find the car feels too wallowey on cornering and turn-in responses. I also think it feels slightly more grippy with the higher pressures I mentioned. The harder ride really doesn't bother me, as I used to drive a Type R, so the GTI's ride is beautiful in comparison, even with higher pressures. I'm running 17" Monzas with Conti 2s. Link to comment Share on other sites More sharing options...
ludwig Posted January 10, 2008 Report Share Posted January 10, 2008 Same as JonnyGTI, I run mine at about 30 psi all round. I prefer the ride it gives. I've done nearly 18k on the original Contis on 17" Monzas. I get a consistent 35 mpg on a long run - so there can't be too much rolling resistance Ludwig Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted January 10, 2008 Report Share Posted January 10, 2008 I always check my tyres on a coolish day and go for 1psi over the recommended value. I personally definitely wouldn't go less than a PSI or two than the recommended with the 18's. If you hit a pot hole, you might find it dents your pocket! Link to comment Share on other sites More sharing options...
JonnyGTi Posted January 10, 2008 Report Share Posted January 10, 2008 It's interesting that on Michelins website they seem happy enough to recommend 32PSI for the fronts and 29PSI on the back for normal driving conditions. For the Michelin Exaltos (oem on my ED30) they even suggest 29PSI all round. Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted January 10, 2008 Report Share Posted January 10, 2008 It's interesting how recommendation can vary by so much! Could it be to do with sidewall strength I wonder? Link to comment Share on other sites More sharing options...
Rachel Posted January 10, 2008 Report Share Posted January 10, 2008 Sidewall rigidity and toughness is a big factor - as is the types/conditions of roads you regularly use. I run my Yokohama V103s (18") at 40psi all round while in the bedding in period, then after 1000km, pump the fronts to 42 and drop the rears to 38... Link to comment Share on other sites More sharing options...
mikemod Posted January 11, 2008 Report Share Posted January 11, 2008 [ QUOTE ] It's interesting that on Michelins website they seem happy enough to recommend 32PSI for the fronts and 29PSI on the back for normal driving conditions. For the Michelin Exaltos (oem on my ED30) they even suggest 29PSI all round. [/ QUOTE ] I queried that with Michelin as when I got the PS2s fitted their recommended pressure was 29psi all round even though the fuel flap said 35psi. their reply was You would be advised to follow values indicated on the fuel cap / door-pillar / vehicle handbook in relation to the tyre size fitted – specifications can change without our knowledge. Link to comment Share on other sites More sharing options...
RedRobin Posted January 11, 2008 Report Share Posted January 11, 2008 I just posted this in another thread but it also seems relevant here, so: For what it's worth I read in one of WHSmith's high street libraries this morning in one of the car mags (I read them all so can't remember which one), that a survey has exposed the fact that many [uK] petrol station tyre pressure monitors are inaccurate and so not reliable. HTH Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted January 11, 2008 Report Share Posted January 11, 2008 I think that would be this week's Auto Express Robin. Bit of a shocker really. I thought by law all of these public facilities had to be inspected annually for accuracy Link to comment Share on other sites More sharing options...
TwoSheds Posted January 11, 2008 Report Share Posted January 11, 2008 I think petrol station air line pumps have been infamous for years... you only had to see how some people treated them literally threwing them on the ground after use. Link to comment Share on other sites More sharing options...
Cuprabob Posted January 11, 2008 Report Share Posted January 11, 2008 It's worth paying a few quid for a good guage Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted January 11, 2008 Report Share Posted January 11, 2008 Yep, I use my own accurate gauge and foot pump. It amazes me that VW for example will fit as standard a bottle opener in the cup holder worth about £10 when a much more useful feature in term of both safety and convenience would be a digital tyre pressure gauge. The same goes for BMW with those hopeless rechargeable torches they fit in the glove box. Link to comment Share on other sites More sharing options...
Cuprabob Posted January 11, 2008 Report Share Posted January 11, 2008 [ QUOTE ] Yep, I use my own accurate gauge and foot pump. It amazes me that VW for example will fit as standard a bottle opener in the cup holder worth about £10 when a much more useful feature in term of both safety and convenience would be a digital tyre pressure gauge. The same goes for BMW with those hopeless rechargeable torches they fit in the glove box. [/ QUOTE ] A very good point Link to comment Share on other sites More sharing options...
ludwig Posted January 15, 2008 Report Share Posted January 15, 2008 TT, <I personally definitely wouldn't go less than a PSI or two than the recommended with the 18's. If you hit a pot hole, you might find it dents your pocket! > Good point and noted particularly as I'm thinking of getting some 18" Detroits soon. ludwig Link to comment Share on other sites More sharing options...
gb110430 Posted January 15, 2008 Report Share Posted January 15, 2008 is halfords a place where i can get a decent tyre pressure gauge and are you suggesting its better to go 2 point higher psi so pot holes have less of an effect? Link to comment Share on other sites More sharing options...
