RedRobin Posted January 22, 2008 Report Share Posted January 22, 2008 Not to everybody's taste (especially on TSN where most are not particularly into modding) but these LED rear clusters are manufactured for and ordered by VW and are RUMOURED to appear on build 09 European GTI's (also R32's??) this summer. The existing Mk5 rear lights are poorly designed in that if you are on the brakes and also indicating, the turn signal is not clearly defined. The guy who owns this Steel Grey GTI has had them on for more than 6 months without any problems. Being European the reversing and fog lenses are the wrong way round for the UK but 'tis a very simple matter to swop the inner lenses: Approx half hour with cutting knife then hot glue gun: Cut the plastic sealing tabs off. Lift out the lenses. Cut the inner tabs down. Swap the lenses over (you might have to dremell the alignment holes). Seal where the plastic sealing tabs were with the hot glue gun. Reassemble. Unlike the American Mk5's, we already have the 4th wire and so don't need to do any extra fiddling. Also we don't need to use VAGcom afterwards - It's simply a matter of plugging in the connectors. The ECU instructions are unchanged and also bulb-out warnings aren't affected. Apparently the connectors do need a strong push to ensure they work properly. Indicator repeat rate remains the same too but response of the lights is more instant - I'm guessing that the rear LED brake lights might illuminate a fraction before the non-LED strip brake light - I'll have to test that. A pair of lights are available in the UK from VWSpeed for £249 incl vat & mainland shipping: VWSPEED WEB PAGE (This page now needs updating re VAGcom not being needed for European cars) Thanks to Neo (who I met through TSNer Chungster) for all the helpful info. He fitted them himself on his Laser Blue GTI and it has since past its first MOT with these LED's. I'll post pics and report further when mine is done in the next few days. Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 22, 2008 Report Share Posted January 22, 2008 [ QUOTE ] Not to everybody's taste (especially on TSN where most are not particularly into modding) but these LED rear clusters are manufactured for and ordered by VW and are RUMOURED to appear on build 09 European GTI's (also R32's??) this summer. The existing Mk5 rear lights are poorly designed in that if you are on the brakes and also indicating, the turn signal is not clearly defined. The guy who owns this Steel Grey GTI has had them on for more than 6 months without any problems. Being European the reversing and fog lenses are the wrong way round for the UK but 'tis a very simple matter to swop the inner lenses: Approx half hour with cutting knife then hot glue gun: Cut the plastic sealing tabs off. Lift out the lenses. Cut the inner tabs down. Swap the lenses over (you might have to dremell the alignment holes). Seal where the plastic sealing tabs were with the hot glue gun. Reassemble. Unlike the American Mk5's, we already have the 4th wire and so don't need to do any extra fiddling. Also we don't need to use VAGcom afterwards - It's simply a matter of plugging in the connectors. The ECU instructions are unchanged and also bulb-out warnings aren't affected. Apparently the connectors do need a strong push to ensure they work properly. Indicator repeat rate remains the same too but response of the lights is more instant - I'm guessing that the rear LED brake lights might illuminate a fraction before the non-LED strip brake light - I'll have to test that. A pair of lights are available in the UK from VWSpeed for £249 incl vat & mainland shipping: VWSPEED WEB PAGE (This page now needs updating re VAGcom not being needed for European cars) Thanks to Neo (who I met through TSNer Chungster) for all the helpful info. He fitted them himself on his Laser Blue GTI and it has since past its first MOT with these LED's. I'll post pics and report further when mine is done in the next few days. [/ QUOTE ] I'll have a look into this tomorrow to see if they are definately OEM. I know VW offer an LED light kit under the Accessories programme but if they are standard from 09 Model year I'll be all over these like a Donkey on a waffle Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 22, 2008 Report Share Posted January 22, 2008 Looks like they've been part of the Accessories Catalogue since early 2007 Part number 1K0052204 Link to comment Share on other sites More sharing options...
PND Posted January 22, 2008 Report Share Posted January 22, 2008 Red Looking forward to seeing pics of the install - particularly what they look like lit up in their full glory! I might be tempted by a pair.... Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted January 22, 2008 Report Share Posted January 22, 2008 They do look good. I've had my eye on these a while a go but couldn't decide if I really liked the silver bits. I've noticed on many cars that the high level LED brake light illiminates a split second before the conventional buld tail lights. They are available from here and they claim to be OEM... Link to LED lights Link to comment Share on other sites More sharing options...
PND Posted January 22, 2008 Report Share Posted January 22, 2008 Are these the same? Video link.. Link to comment Share on other sites More sharing options...
Chungster Posted January 22, 2008 Report Share Posted January 22, 2008 Neo mentioned he was getting these. That boy can't help modding his Golf! Saying that I've been thinking about these ligths ever since I saw that car in Oxford. Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted January 22, 2008 Report Share Posted January 22, 2008 Blimey guys - these could catch on. Might be more common than Lexarse lights on a Saxo in 6 months time Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 22, 2008 Report Share Posted January 22, 2008 It looks like they do a black set rather than a darkened set Shame otherwise they'd definately be going on the .:R If I fitted these it'd look just like a normal Golf Link to comment Share on other sites More sharing options...
RedRobin Posted January 22, 2008 Author Report Share Posted January 22, 2008 ....I'm not sure what you mean by a "black set" but unless professionally photographed with back lighting etc the smoked red parts do look very black. They don't look black on the car though. Link to comment Share on other sites More sharing options...
RedRobin Posted January 22, 2008 Author Report Share Posted January 22, 2008 Post deleted by RedRobin Link to comment Share on other sites More sharing options...
RedRobin Posted January 22, 2008 Author Report Share Posted January 22, 2008 [ QUOTE ] [ QUOTE ] Are these the same? Video link.. [/ QUOTE ] ....Yes, looks like the same to me Good find, Paul . Link to comment Share on other sites More sharing options...
silentandy Posted January 22, 2008 Report Share Posted January 22, 2008 [ QUOTE ] Looks like they've been part of the Accessories Catalogue since early 2007 Part number 1K0052204 [/ QUOTE ] Is that a RHD version that doesn't need modding? Link to comment Share on other sites More sharing options...
Muppetboy Posted January 22, 2008 Report Share Posted January 22, 2008 RR, I agree when braking you cannot see the indicator and this is bloody annoying when you're following another Golf. Can't say I like the LED's though... looks like they are available on Fischer Motorsports website. Incidentally I had a bit of a play with a red GTI on the way to work this morning, I often see it but the driver is a bit of an old fogey so have never bothered to play. This morning though I really gave it some beans coming out of a junction and he followed suit, and we were off... And yes to reconfirm grey GTI's are faster than red ones. Link to comment Share on other sites More sharing options...
RedRobin Posted January 22, 2008 Author Report Share Posted January 22, 2008 [ QUOTE ] [ QUOTE ] Looks like they've been part of the Accessories Catalogue since early 2007 Part number 1K0052204 [/ QUOTE ] Is that a RHD version that doesn't need modding? [/ QUOTE ] ....Andy, the one in the pic has the red fog lens on the left and is therefore a lefthand drive car. Link to comment Share on other sites More sharing options...
RedRobin Posted January 22, 2008 Author Report Share Posted January 22, 2008 ....Muppetboy - They are about £50 more from FischerSport and might attract import duty. Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 22, 2008 Report Share Posted January 22, 2008 I'll look into lights tomorrow re: RHD compatibility Link to comment Share on other sites More sharing options...
RedRobin Posted January 22, 2008 Author Report Share Posted January 22, 2008 [ QUOTE ] I'll look into lights tomorrow re: RHD compatibility [/ QUOTE ] .... I thought we had already established that these lights are RHD compatible if you swop over the reverse and fog lenses (as my original post). Link to comment Share on other sites More sharing options...
petsy Posted January 22, 2008 Report Share Posted January 22, 2008 [ QUOTE ] ....Muppetboy - They are about £50 more from FischerSport and might attract import duty. [/ QUOTE ] there will be no import duty payable at the UK end as Germany is in the EU. Link to comment Share on other sites More sharing options...
Nelson_R32 Posted January 22, 2008 Report Share Posted January 22, 2008 [ QUOTE ] [ QUOTE ] I'll look into lights tomorrow re: RHD compatibility [/ QUOTE ] .... I thought we had already established that these lights are RHD compatible if you swop over the reverse and fog lenses (as my original post). [/ QUOTE ] I meant more do some research into whether there is a RHD part number available from Volkswagen Accessories. Or, if it is true LED's will be on 2009 Model Year, ETKA Link to comment Share on other sites More sharing options...
RedRobin Posted January 22, 2008 Author Report Share Posted January 22, 2008 ....Thanks, petsy . Now I recall that you've told me that before!! Link to comment Share on other sites More sharing options...
RedRobin Posted January 22, 2008 Author Report Share Posted January 22, 2008 ....Thanks for clarifying, Nelson . It's possible that they won't be available for the UK because the internal fog and reverse lenses can't be swopped over without some jiggery pokery. The screw holes don't line up when swopped - Hence drimmel and hot glue gun - I've just read an independent report confirming this on another forum. If the VW design team were really efficient they would have designed the units to allow simple swop of lenses to cater for both markets. It certainly would have been my design brief! I hope I'm wrong but I reckon the UK will be left out. Link to comment Share on other sites More sharing options...
Spot Posted January 23, 2008 Report Share Posted January 23, 2008 No import duty from Fischer Motorsport as they're in the EU, only extra is carriage - I've bought a few odds and sods from them Link to comment Share on other sites More sharing options...
cmdrfire Posted January 23, 2008 Report Share Posted January 23, 2008 'lo all, Don't usually post here but since I was mentioned here I am;) LED tails: [image] [/image] at night: [image]http://farm3.static.flickr.com/2328/2142967665_8fe35ee679.jpg[/image] As Robin has said, I just passed my MOT without any trouble at all with these LED lights. The procedure to do the red fog/white reverse is very simple and took me about 45 minutes; the light swap itself is just a straight go, so to speak Grr, my images aren't showing... alright, I can't figure this out. Someone hotlink my images for me Edit the Third: Here's a link to the Flickr set with my photos: Flickr Set Link to comment Share on other sites More sharing options...
Matt R Posted January 23, 2008 Report Share Posted January 23, 2008 [ QUOTE ] Don't usually post here but since I was mentioned here I am;) [/ QUOTE ] Maybe you should visit here more often! Link to comment Share on other sites More sharing options...
