CarMad Posted February 2, 2008 Report Share Posted February 2, 2008 If I want this can I add it to my e90 3 and will it allow me full control on the I-drive and be able to see the songs lits etc. Oh and will my wallet take a battering in the process. Link to comment Share on other sites More sharing options...
Andrew Posted February 2, 2008 Report Share Posted February 2, 2008 I've seen the iPod on a car without iDrive (335d) and you get more control than I've seen before - playlists come up on the display etc etc. Pretty good from what I saw. Might be an indication of how good it could be with your iDrive. Link to comment Share on other sites More sharing options...
gizze Posted February 2, 2008 Report Share Posted February 2, 2008 You can get the Dension Gateway 500 which gives full control and allows usb sticks etc. Have you got a cd changer?? You need the car to be programmed for one of these for it to work. Link to comment Share on other sites More sharing options...
CarMad Posted February 2, 2008 Author Report Share Posted February 2, 2008 Nope only the standard bits no autochanger. Any idea what this might cost, I guess if the dealer needs 5 mins to put a plug in the car they will take me to the cleaners. Link to comment Share on other sites More sharing options...
edo Posted February 2, 2008 Report Share Posted February 2, 2008 If you have nav it is all optical and as gIzze says, you'll need a Dension 500. I think they are about 250, possible to fit yourself, or a couple of hours to a car audio place. Link to comment Share on other sites More sharing options...
gizze Posted February 2, 2008 Report Share Posted February 2, 2008 Yeah dead easy to fit it, takes about 10 minutes, however you need to have the car programmed for a cd changer, and you need to have a changer in there before the dealer will code it. So it is a lot of effort and not cheap. You can get the BMW kit fitted, not as good as the factory 6FL USB option and they charge you around £500 for it all. Link to comment Share on other sites More sharing options...
edo Posted February 2, 2008 Report Share Posted February 2, 2008 what a piss take - so the dealer wont code for a changer unless you buy one? I've heard it all now. Link to comment Share on other sites More sharing options...
gizze Posted February 3, 2008 Report Share Posted February 3, 2008 The dealer can't code for a changer unless one is fitted. So best to buy one on ebay cheap and then get them to code it if that is the route you want to take. Link to comment Share on other sites More sharing options...
Cleybrooke Posted February 4, 2008 Report Share Posted February 4, 2008 How easy is it to get the USB fitted in the centre as an after market option? Link to comment Share on other sites More sharing options...
gizze Posted February 4, 2008 Report Share Posted February 4, 2008 It's not. I have not heard of anyone managing it as yet. Have a look at the thread on e90post.com Link to comment Share on other sites More sharing options...
SamD Posted February 4, 2008 Report Share Posted February 4, 2008 I phoned BMW last week for a quote to fit the iPod interface into my 535d. The part is £200 and they want £600 to fit and code. Not surprisingly I told them to feck off. I already have the changer fitted, so it really is a simple matter of removing it and plugging in the iPod kit. Sadly (according to a lot of the BMW forums) doing this without recoding may cause diagnostics errors when the car is being serviced..... I have bought a dension gateway 500, but I am having a few issues with my iDrive at the moment so have not yet fitted it.... Link to comment Share on other sites More sharing options...
SamD Posted February 4, 2008 Report Share Posted February 4, 2008 I am tempted to just get BMW to fit the Aux interface, but I suspect I will get just as stung on labour! Link to comment Share on other sites More sharing options...
gizze Posted February 4, 2008 Report Share Posted February 4, 2008 Sam, if you have a cd changer the Dension simply plugs in its place. Takes two minutes to fit mate and works a charm! Link to comment Share on other sites More sharing options...
SamD Posted February 4, 2008 Report Share Posted February 4, 2008 [ QUOTE ] Sam, if you have a cd changer the Dension simply plugs in its place. Takes two minutes to fit mate and works a charm! [/ QUOTE ] The dension doesn't replace the CD changer it is an addition and as such needs it's own power etc etc. I know it is a simple fit, but I am holding off to get my other iDrive issues resolved Link to comment Share on other sites More sharing options...
highflyin Posted February 5, 2008 Report Share Posted February 5, 2008 Can't you just use the AUX port in the armrest stowage area and change on the ipod? That's what I do. Must admit it would be better to have the cable into the glovebox solution with control on the steering wheel though. I thought to get the integrated method it was just a cable plugged into the back of the business radio and run through to the glovebox - there's more to it? Link to comment Share on other sites More sharing options...
PeterS Posted February 5, 2008 Report Share Posted February 5, 2008 [ QUOTE ] Can't you just use the AUX port in the armrest stowage area and change on the ipod? That's what I do. Must admit it would be better to have the cable into the glovebox solution with control on the steering wheel though. I thought to get the integrated method it was just a cable plugged into the back of the business radio and run through to the glovebox - there's more to it? [/ QUOTE ] I've never seen an E9x series with a business radio; don't they all have the BMW professional stereo as the standard spec... Link to comment Share on other sites More sharing options...
CarMad Posted February 6, 2008 Author Report Share Posted February 6, 2008 So I spend £250 min plus get it fitted myself and get BMW to code something and then have to buy an Autochanger to throw away. Or give them £500ish for something inferior when the device I'm connecting costs half that. Erm .. great options BMW. (Yes I know its cheaper when spec'ed as new) Link to comment Share on other sites More sharing options...
highflyin Posted February 6, 2008 Report Share Posted February 6, 2008 Sorry - yep ! Professional readion not 'Business'. Link to comment Share on other sites More sharing options...
edo Posted February 6, 2008 Report Share Posted February 6, 2008 I'm sure if you where getting your car serviced they'd code it for CD changer if you had fitted a Dension??? Link to comment Share on other sites More sharing options...
gizze Posted February 6, 2008 Report Share Posted February 6, 2008 You need a changer fitted otherwise you get coding errors. The dension has a service switch on it, and you have to put it in service mode when you take the car in, otherwise they can't code the car for anything as it throws up errors when they try, and not just for the stereo, anything in the car. Link to comment Share on other sites More sharing options...
CarMad Posted February 6, 2008 Author Report Share Posted February 6, 2008 Nothing in the Dension info mentions the autochanger requirement for the BMW kit. I guess its the way the car needs to talk to the denison to make it work. £250 seems reasonable, £500 is too much IMO. Link to comment Share on other sites More sharing options...
gizze Posted February 7, 2008 Report Share Posted February 7, 2008 No, and it is a bit naughty of Dension not to mention it. Alot of people have had their fingers burnt. Link to comment Share on other sites More sharing options...
edo Posted February 7, 2008 Report Share Posted February 7, 2008 Hmm, think I will just stick with the aux input. Link to comment Share on other sites More sharing options...
CarMad Posted February 7, 2008 Author Report Share Posted February 7, 2008 [ QUOTE ] Hmm, think I will just stick with the aux input. [/ QUOTE ] Ditto unless something else comes out or the requirement changes. Link to comment Share on other sites More sharing options...
