Blaa Posted December 9, 2003 Report Share Posted December 9, 2003 Yeah!!! But back to topic.. If I ever get my car over to the UK, I'll invest in that drive by wire.. The sharan had it, and I liked it.. Link to comment Share on other sites More sharing options...
Foggy Posted December 9, 2003 Report Share Posted December 9, 2003 If I understand correctly ( I'm sure someone will tell me if I don't ) drive by wire simply means that there is no direct cable connection from the accelerator pedal, it's electronic rather, it's not something you can get fitted Link to comment Share on other sites More sharing options...
Blaa Posted December 9, 2003 Report Share Posted December 9, 2003 I know, but the CC is DBW right?? I know I can fit it, well the AmD site said so. Link to comment Share on other sites More sharing options...
Foggy Posted December 9, 2003 Report Share Posted December 9, 2003 Yeah if your car is already DBW you can fit it although I think you need to do some stuff with a VAG COM to enable it. Link to comment Share on other sites More sharing options...
grahamb Posted December 10, 2003 Report Share Posted December 10, 2003 DBW means that when you press the throttle pedal, you are not connected to the throttle with a cable. Instead, the pedal position is relayed to the ECU, and it then decides how much to open the servo controlled throttle. So you give it full throttle to jump on to a roundabout, and the ECU says "Nope, thats not economical, I'll give you 30% throttle and then we'll see who's the boss". So you end up slipping the clutch out of frustration, just to make quick starts. I think I prefer not to have DBW myself. But eventually, we wont have any choice in the matter as all new cars are having them as standard. Link to comment Share on other sites More sharing options...
