rag1873
passat central locking
2 posts in this topic
if i open the car using the remore locking, then go in to the boot and then close the boot the whole car now locks.
it didnt used to do this. i only discovered it after locking my keys in the boot!!!! what could cause this??
Not sure about your boot but my drivers door does the same thing. Mine is caused by a faulty drivers door locking module which doesn't recognise that the door is open, therefore doesn't show on the illuminated dashboard, and as such automatically locks the door after a set time.
Perhaps your boot has a faulty lock module too. I will add that my car is the estate. The module can usually be repaired as it is often a broken solder joint on a microswitch/circuitboard caused by constant slamming of the door/boot etc.
To stop my car locking with the keys in I also open/close any other door as well. This then 'registers' that the car has been unlocked and doesn't attempt to re-lock it with your keys in. At least it gives you time to get it fixed.
