Rill Posted July 12, 2008 Report Share Posted July 12, 2008 Hello! I'm looking at getting a MY07 VW Caddy 1.9 TDi revo'd and wondered if anyone could recommend a decent specialist in the Yorkshire area that could do it for me? I've also read about a separate device I can buy that will allow me to switch the map back to stock. Do any of you use such a device and can pass on your experiences? Am I right to assume the ECU can handle just a single map and this device will allow me to switch between the Revo software and the stock map or isn't it as straightforward as that? Thanks in advance. Link to comment Share on other sites More sharing options...
Rustynuts Posted July 12, 2008 Report Share Posted July 12, 2008 Hello.:D If you want a switcheable mapping solution then here's what you do. Contact Jayson at Chipped UK and see what he says about doing your Caddy. They do a device called the ST3 (Self Tuning 3) which gives you the stock map, and a choice of 2 other maps from economy, fast road, and race. You can switch between them as much as you like just by connecting the unit and selecting which map you want. I have the economy map on my Altea and although I don't see a great improvement over stock mpg it's a lot more driveable. It may be that they don't have the ST3 set up for the Caddy yet, but see what he says. Also, I've sent you a pm about this issue aswell. Link to comment Share on other sites More sharing options...
Rill Posted July 12, 2008 Author Report Share Posted July 12, 2008 Thanks for that matey, much appreciated. I'll look into it. Link to comment Share on other sites More sharing options...
