allan1970 Posted August 11, 2008 Report Share Posted August 11, 2008 hi i have a 1994 wrx impreza with a new engine in and it will not run on the left hand side of the engine very well cylinders 1 and 3 parts that have been checked are as follows. injectors , fuel pressure ,coil packs , plugs, ecu , lamba sensor, maf sensor, temp sensor, and the compression is fine on all cylinders . any help would be much appreciated as it has been off the road for six weeks now and im pretty stuck now cheers Link to comment Share on other sites More sharing options...
PetrolDave Posted August 12, 2008 Report Share Posted August 12, 2008 Any particular reason you have posted this in the VAG-COM forum? Link to comment Share on other sites More sharing options...
