Bagnallc Posted September 3, 2008 Report Share Posted September 3, 2008 I have the water leak in my passat i have cleared the drains under the battery as it was full of water thought i had problem resolved. Rained very heavy last night and got in car this morning to find a puddle of water on my rubber mats on passenger side of car where else can this car leak to cause thi? I have again checked under the battery and it is clear of water and drains are still clear. I don't have a sunroof. Link to comment Share on other sites More sharing options...
pontyslapper Posted September 4, 2008 Report Share Posted September 4, 2008 I'd check the window seals and door seals are clear. You never know if theres a build up of that greeny mossy looking stuff on your seals it may cause capilliary action to allow the water in. Also, simple though it seems, check the windows are up properly - simple thing to miss especially if someone else has been 'playing' with them - had that happen to me with my missus - put the window up on passenger side and stopped before it was right home - luckily no water ingress but a bloody irritating whistling noise the next day that I didn't realise until I'd stopped to chat to a mate and used the passenger window! Link to comment Share on other sites More sharing options...
gypsyboy Posted September 6, 2008 Report Share Posted September 6, 2008 hello check other previous posts regarding water leaks there is loads!!! it may be easier to check than expects replys. these cars are great but they suffer with water leak problems. which is rubbish. Link to comment Share on other sites More sharing options...
kite Posted September 6, 2008 Report Share Posted September 6, 2008 The pollen filter seals are known to leak. Link to comment Share on other sites More sharing options...
passatchris Posted September 7, 2008 Report Share Posted September 7, 2008 hi, i had the same problem,mega leak and lots of water on the car. check these links out. if the waterhas got to your ccu then you might have some more work on your hands chris :: .:: WeirdLittleBiscuit dot Com ::. .:: Fixing Passat Leak ::. :: and this link for the ccu VW Passat Comfort Control Module harness repair | HeadFUZZ Link to comment Share on other sites More sharing options...
sam1969 Posted June 7, 2009 Report Share Posted June 7, 2009 The pollen filter seals are known to leak. i have try everything i have used silicone to seal pollen fillter i have taken battery out and cleaned plug holes and drained excess water and still leaking. i have cleaned door seals should i get new seal for pollen fillter as i tryed silicon and it has not worked my pasatt is 1.8 20v lpg 1998 estate anyone please help Link to comment Share on other sites More sharing options...
chris m Posted July 3, 2010 Report Share Posted July 3, 2010 There was a factory recall to do a mod to the drain hole under the battery. Contact a VW dealer. Link to comment Share on other sites More sharing options...
