laketahoe Posted September 27, 2008 Report Share Posted September 27, 2008 Hi all Need some advice on things to look for on a Cayman S which i am looking to buy tomorrow (29th Sept). I have done a lot of research on this but always trust judgement offered on this forum. the car is generally in mint condition as it has only sone 8k however the bumper is covered in stone chips and the passanger side front tyre has worn considerably on the outside. I understand this is not uncommon regarding the stone chips but it will need a paint job but am a little concerned about the tyre wear. I will be having an independent inspection done but this is expensive so wanted to rule out any issues up front Your thoughts, suggestion will be greatly appreciated thanks Stu Link to comment Share on other sites More sharing options...
Gareth Posted October 7, 2008 Report Share Posted October 7, 2008 Stu Porsches are very susceptible to their geometry being out of tolerance. This can happen from something as simple as a minor kerb incident when parking so maybe something to not get too worried about at the moment. Did you buy the car that was inspected after all?? Link to comment Share on other sites More sharing options...
richy_uk Posted October 7, 2008 Report Share Posted October 7, 2008 An alternative reason could be the car has been tracked and the owner has had a little bit of an 'off' Link to comment Share on other sites More sharing options...
