funguf Posted October 10, 2008 Report Share Posted October 10, 2008 (edited) Hi All, Had the following work done to a 2002 Polo: - - fuel sensor (had a funny smell) - egr valve blew up (replaced) - abs sensor (ended up replacing abs control unit which didnt fix this) - timing chain (cogs replaced ££££) - front brushes worn and waering out tyres (replaced) - ignition coil (emissions warning light) - partially blocked cat converter (cleared itself) - funny noise from fuel pump (fixed itself) - rear right central locking pump not working (fixed itself) - engine management light (epc warning light, no brake lights - fixed itself) - single front sidelight bulb blew ;-) Bought it from first owner in 2005, and its all gone wrong!! seems to be working ok at the moment....but for how long?? Edited October 10, 2008 by funguf Link to comment Share on other sites More sharing options...
Mouse Posted October 13, 2008 Report Share Posted October 13, 2008 Sounds like you have an unlucky car. A few of those problems are common on newer problems, but not everything there at the same time Link to comment Share on other sites More sharing options...
