audi_novice Posted January 19, 2009 Report Share Posted January 19, 2009 Both doors on my A3 have a leak when it rains. The leak seems to be coming from the door seal at the top of the door.. Do i need to replace the seal? Is this a common problem ? Link to comment Share on other sites More sharing options...
dq1 Posted January 19, 2009 Report Share Posted January 19, 2009 Has anyone had the doors off to do any work? I had this problem with the drivers door as the garage had not reseated it properly after fitting a new wiring loom. I also got a rushing sound through the top of the door when driving at speed I took it back and they sorted the door alignment Link to comment Share on other sites More sharing options...
audi_novice Posted January 19, 2009 Author Report Share Posted January 19, 2009 It hasnt had any work done since I got the car but its possible it did have before i got it. Ill get it checked out. Thanks Link to comment Share on other sites More sharing options...
Mr Man Posted January 19, 2009 Report Share Posted January 19, 2009 Both doors on my A3 have a leak when it rains. The leak seems to be coming from the door seal at the top of the door.. Do i need to replace the seal? Is this a common problem ? I had this problem a few years ago with my A3....the car was only a few months old....On one occasion after a severe storm there was literally a puddle in the rear, passenger side footwell.The door seals and the entire interior carpets were replaced under warranty....a friend had a leaky door seal on a Seat Cupra,so this could be a common problem....strangly I had exactly the same issue with a Toyota Celica 15yrs ago....again everything replaced under warrenty....So I have to ask the question....Is your car still under warrenty?.....if it`s not I have a strange feeling that the replacing door seals is probably a black art...if you`v never done it before or don`t know what your doing you may end up making the problem worse. Link to comment Share on other sites More sharing options...
sthekidy Posted January 22, 2009 Report Share Posted January 22, 2009 See the answer click here. Want to see more pics? Show yourself on our forum click here Recommend:Sexy Halloween CosplaySakurai cypress's cosplay Link to comment Share on other sites More sharing options...
