graeme86 Posted January 20, 2009 Report Share Posted January 20, 2009 Do you have a Mark V R32 with the oil sensor fitted in the sump? If so, can you please advise where the harness runs up the side of the engine from it? What I mean is, is it fed down around the gearbox bell housing side (same as most four cylinders) or does it come up the pulley side of the block (like the Mark IV wiring did)???? It seems that the Aussie ones don't have the sensor fitted, otherwise I'd look myself! Just trying to work out what clamps/heatwrap etc I need to fit one. Thanks for any information/photos. Link to comment Share on other sites More sharing options...
