M7R Posted February 17, 2009 Report Share Posted February 17, 2009 how hard is it to take the headlights off the B7 A4?? is it a bumper off job? cheers Karl. Link to comment Share on other sites More sharing options...
Cupramax Posted February 17, 2009 Report Share Posted February 17, 2009 Nope its easy, remove two big hex bolts on the cross member above the lights and one down each side which you just need to loosen. Headlight then slides out. Link to comment Share on other sites More sharing options...
M7R Posted February 17, 2009 Author Report Share Posted February 17, 2009 can it be done with out removing the bumper? "preys it can":o Link to comment Share on other sites More sharing options...
Cupramax Posted February 17, 2009 Report Share Posted February 17, 2009 Is it a bumper off, "nope" was a clue Link to comment Share on other sites More sharing options...
M7R Posted February 17, 2009 Author Report Share Posted February 17, 2009 wicked! just wanted to make sure Link to comment Share on other sites More sharing options...
MattS3 Posted February 17, 2009 Report Share Posted February 17, 2009 but I think you need to get them re-aligned once they've been out. Link to comment Share on other sites More sharing options...
M7R Posted February 17, 2009 Author Report Share Posted February 17, 2009 ok ok which bolts are the big hex ones? as I undid the 3 torques bolts that old the unit in but it wont come out past the bumper :confused: any pics of what bolts you mean? Link to comment Share on other sites More sharing options...
fly300kts Posted February 18, 2009 Report Share Posted February 18, 2009 Bumper has to be removed !!!!!!! Link to comment Share on other sites More sharing options...
maersk Posted February 18, 2009 Report Share Posted February 18, 2009 November 2004 on:- Removing and installing headlights Removing– Remove front bumper cover :ffs: – Remove bolt -3-.– Loosen bolts -1- and -2- a few turns but do NOT unscrew completely.– Remove headlight from body towards front. InstallingInstallation is carried out in the reverse order; note the following:– Check adjusting nut -1- of adjuster for freedom of movement -arrows-.– Screw down adjusting nut as far as it will go, but do not tighten. – Insert headlight and screw in bolts -1 ... 3- two complete turns.– Install front bumper cover → Rep. Gr.63.– Align headlight with body contours and front bumper cover (note gap widths).– Tighten bolts in the sequence -2-, -1- and -3-. Note When the bolts are tightened the adjusting nut of the adjuster element automatically rotates against the mounting point of the headlight housing and fixes it in place.– Check gaps; if necessary, repeat procedure for installing headlight.– Following installation, adjust headlights – Unplug electrical connector. Link to comment Share on other sites More sharing options...
MrAvant Posted February 19, 2009 Report Share Posted February 19, 2009 Yep the bumper does have to be removed as Audi recently had to replace my headlight and cocked up the re-fiiting of the bumper.....Amatuers!!!!! Link to comment Share on other sites More sharing options...
Cupramax Posted February 19, 2009 Report Share Posted February 19, 2009 You do not need to remove the bumper... Remove screws -1- and -5-. Loosen screws -2- and -4- several turns but do not remove completely. Separate wire connectors where installed. Disconnect electrical harness connector -3-. Remove headlight from body toward the front. Link to comment Share on other sites More sharing options...
maersk Posted February 19, 2009 Report Share Posted February 19, 2009 Is that 'cos its a Cab.? Link to comment Share on other sites More sharing options...
PetrolDave Posted February 20, 2009 Report Share Posted February 20, 2009 Cabs stayed with the B6 design for sometime before changing to the B7. The easiest way to tell is look at the headlight shape - if it's like a B6 saloon/Avant then you DON't need to remove the bumper if it's like the B7 (all curvy) then you do - at least that's what I reckon. Link to comment Share on other sites More sharing options...
Cupramax Posted February 20, 2009 Report Share Posted February 20, 2009 Is that 'cos its a Cab.? Why the A b7 front end is a b7 front end, the cab is no different unlike the B6 Link to comment Share on other sites More sharing options...
PetrolDave Posted February 20, 2009 Report Share Posted February 20, 2009 Why the A b7 front end is a b7 front end, the cab is no different unlike the B6 The drawing you've posted above is for a B6, but the B7 has part of the headlamp that is behind the bumper cover so you cannot remove the headlamp on a B7 without at least loosening and dropping the bumper cover. Link to comment Share on other sites More sharing options...
ivor2 Posted February 20, 2009 Report Share Posted February 20, 2009 nearly certain the bumper has to come off if you want to fully remove the lights , forward thinking in car design? Link to comment Share on other sites More sharing options...
PetrolDave Posted February 20, 2009 Report Share Posted February 20, 2009 nearly certain the bumper has to come off if you want to fully remove the lights , forward thinking in car design? A symptom of the B7 being a facelift of the B6 - the B6 was designed for ease of build and repair, but the B7 lost that in the name of style... Link to comment Share on other sites More sharing options...
maersk Posted February 20, 2009 Report Share Posted February 20, 2009 Curvy lights = removal Sensitivity where there was no intention other than a little brevity added to a question.................... Link to comment Share on other sites More sharing options...
sc00byd00byd00 Posted March 27, 2009 Report Share Posted March 27, 2009 More to the point, how do you remove the front bumper ???? :ffs::ffs: Link to comment Share on other sites More sharing options...
gats0man Posted May 13, 2009 Report Share Posted May 13, 2009 You can get all the needed bolts loosened and removed easy enough - it is the shape of the headlamp itself which makes it so you have to remove the bumper cover. The lights themselves curve downwards at the bottom so when you tug at the lamp it catches on the plastic . Removing the front bumper looks like a nightmare though - check out AudiWorld Tech Articles Link to comment Share on other sites More sharing options...
M7R Posted May 25, 2009 Author Report Share Posted May 25, 2009 there ios no way the light comes out with the bumper in place, its too deep behind the bumper to come out to remove the front bumper its a bit of a chore but do able... remove the under tray then remove the arch liners then you will see on the drivers side 2 bolts going up into the wing, one close to the arch the other closer to the bumper, then there are 2 nuts to remove from the studs at the front that face you, same on the other side, but the waher bottle has to be un bolted and pulled out of the way. there is also bolts on the slam pannel and i think in where the fog lights are iirc (been a while since I did this...) the majority are torques T20 iirc....but dont hold me to that.. then the bumper unclips and slide forward... then the lights can be slid out. Link to comment Share on other sites More sharing options...
wyliss Posted October 16, 2009 Report Share Posted October 16, 2009 My n/s headlight seems to have a film/possibly dirt on the inside of it, it doesnt look as clean and clear as the other one. Are you able to unclip the cover from the top where there are two black metal clips present? Cheers Link to comment Share on other sites More sharing options...
maersk Posted October 16, 2009 Report Share Posted October 16, 2009 No..................... Link to comment Share on other sites More sharing options...
wyliss Posted February 10, 2010 Report Share Posted February 10, 2010 So does the bumper need to come off on a B7 for a headlamp replacement ? Link to comment Share on other sites More sharing options...
PetrolDave Posted February 11, 2010 Report Share Posted February 11, 2010 So does the bumper need to come off on a B7 for a headlamp replacement ? Yes. B6 - no. B7 - yes. B8 - don't know. Link to comment Share on other sites More sharing options...
