ludwig
VW key disassembly - replacing battery
10 posts in this topic
After just over 3 years, I need to replace the battery on my MkV GTI key.
Any tips please on pulling it apart - so it separates in two halves!
I could manage my MkIV key no problem.
It was very satisfying not having to take it to the dealer's :-)
Thanks, Ludwig
Ah yes, you wouldn't want to take it to the dealers because of all the Skodas they have there!
My Skoda key pulls apart with a little persuasion, although it won't be as well built as your VW one.
shark_90, yes, I would expect the Skoda part to pull apart easily! :-)
Ludwig
mb, thanks.
I'm using all my strength - but nothing is happening .... :-)
Is there a catch or tongue you need to press down on as you pull apart?
Ludwig
mb, I had a good meal, then tried again this evening!
It came apart!!
I used:
riskinit.com
to help me.
Ludwig
Thanks for that - the local stealers want a literal "arm and leg" to do anew battery here...
i just stopped working at a vw dealer, i used to swap the battery for free and all you paid was the replacement part.
Chances are you'll need a pretty standard (and cheap) 2032 type battery.
Thats what was in mine!
