vanduara37 Posted April 26, 2009 Report Share Posted April 26, 2009 Can anyone post any info how to remove glow plugs from 2005 A4 2.0 Tdi Thanks Link to comment Share on other sites More sharing options...
BW2309 Posted May 4, 2009 Report Share Posted May 4, 2009 On the 2.0TDi they are under tha cam cover. You remove the cam cover and they are sat next to the PD units. They have a small sound, black plug on them. Just pop the plug off and they unscrew out. Bit of advice.... get the engine really hot before you start to remove the cover. This heat in the engine helps the glow plugs come loose. They do snap off so any help is good!!! I work on these regularly and have never had to swap a glow plug though, what's up with em? Link to comment Share on other sites More sharing options...
vanduara37 Posted May 8, 2009 Author Report Share Posted May 8, 2009 Ran auto scan with vagcom and got 4 fault codes on engine -------------------------- Address 01: Engine Labels: 03G-906-016-BLB.lbl Part No SW: 03G 906 016 GN HW: 028 101 211 3 Component: R4 2,0L EDC G000SG 9618 Revision: 12345678 Serial number: Coding: 0000072 Shop #: WSC 00847 210 86414 4 Faults Found: 17055 - Cylinder 1 Glow Plug Circuit (Q10): Electrical Fault P0671 - 000 - - Freeze Frame: RPM: 567 /min Torque: 126.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 10.72 V Bin. Bits: 00001100 Temperature: 6.3°C Bin. Bits: 01110000 17056 - Cylinder 2 Glow Plug Circuit (Q11): Electrical Fault P0672 - 000 - - Freeze Frame: RPM: 567 /min Torque: 126.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 10.72 V Bin. Bits: 00001100 Temperature: 6.3°C Bin. Bits: 01110000 17057 - Cylinder 3 Glow Plug Circuit (Q12): Electrical Fault P0673 - 000 - - Freeze Frame: RPM: 567 /min Torque: 126.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 10.72 V Bin. Bits: 00001100 Temperature: 6.3°C Bin. Bits: 01110000 17058 - Cylinder 4 Glow Plug Circuit (Q13): Electrical Fault P0674 - 000 - - Freeze Frame: RPM: 567 /min Torque: 126.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 10.72 V Bin. Bits: 00001100 Temperature: 6.3°C Bin. Bits: 01110000 Don,t know if it is the glow plugs or some relay supplying them,i don not have any problems starting the car but even when i clear fault codes they come back after trying to start ? Link to comment Share on other sites More sharing options...
benjie Posted May 10, 2009 Report Share Posted May 10, 2009 I would doubt it's all of the glow plugs, more like the wiring. Also, in these temperatures, the car won't use the glow plugs to start anyway, so you won't nitice a problem until winter. Check the wiring. Link to comment Share on other sites More sharing options...
PetrolDave Posted May 11, 2009 Report Share Posted May 11, 2009 Is there a fuse that supplies the glow plugs? I think there might be a big fuse somewhere near the battery that supplies the glow plugs. Agree that it's very unlikely all 4 glow plugs will have failed and it's more likely to be something common. Link to comment Share on other sites More sharing options...
BW2309 Posted May 16, 2009 Report Share Posted May 16, 2009 Has the car had an in'line tuning box fitted??? The glow plug supply and control feed is from the large rotary plug on the rear of the cylinder head. Check that it is fully locked in and not making a poor connection. If a tuning box had been fitted then this would have been disturbed in fitting or removal. If you want to check that they are plugged in correctly, you can remove the cam cover very easily. Just undo the Torx bolts and it'll come straight off, you dont even have to remove the cam belt cover. You can then see the glow plugs next to the base of the injectors. I'll have a look on the wiring diagrams to check the feeds for you and report back! p.s HAVE YOUR OIL PRESSURE CHECKED! I have done a load of BLB engined 2.0TDi's recently that have lost drive to the oil pump!!!!! Check before you incur damage. It is a big problem and doesn't show as a fault until it's too late and something has broken! Link to comment Share on other sites More sharing options...
vanduara37 Posted May 16, 2009 Author Report Share Posted May 16, 2009 Nothing has been done to the car" totally standard" just ran a random scan as the car was "missing" quite badly when flooring the accellerator but turned out to be a blocked EGR valve (fine now). Link to comment Share on other sites More sharing options...
BW2309 Posted May 17, 2009 Report Share Posted May 17, 2009 Just checked the wiring diagrams. Your glow plugs are fed solely from J179 (glow plug control unit) and this is fed from fuse S39 - this is an 80A strip type fuse on the main vehicle fuse box and is connecting ends of a 6mm RED wire. This could cause a loss of power to all 4, failing that then I'd suggest wiring for all 4 plugs inside the head. Easy engough to check both issues. PM me if you need me to send you copy of diagrams or Elsa info to check either. ANd seriously, please get ya oil pressure checked. I have some pics that would scare you! Link to comment Share on other sites More sharing options...
vanduara37 Posted May 17, 2009 Author Report Share Posted May 17, 2009 ANd seriously, please get ya oil pressure checked. I have some pics that would scare you! How do you check oil pressure ? Link to comment Share on other sites More sharing options...
BW2309 Posted May 17, 2009 Report Share Posted May 17, 2009 You'll prob have to pop it to a garage (a knowledgable one) but you can check it with a guage at the oil pressure switch. Whilst checking, the technician needs to listen for nasty rattle nosies from the oil pump drive or the chain drive tensioner for the balance shaft unit. Link to comment Share on other sites More sharing options...
vanduara37 Posted May 23, 2009 Author Report Share Posted May 23, 2009 BW2309 .I have removed one of the glowplugs and attached meter to it but when i turn on igniton it seems i am getting no power to it,can you tell me where this J179 relay is located as the fuse you mention is ok. Thanks John Link to comment Share on other sites More sharing options...
