vw754
18's gona rub?
8 posts in this topic
hi, i have .....Audi A3 Tdi Sport (5 door sportback),im wanting to take off original 7.5x17'' wheels (ET56) and fit 18'' rs6 replicas....8x18 (ET45).
I was told (BY THE WHEEL PLACE) they will catch the rear arch's (the 18's) but others have told me there ok.
AUDI A3 TDI SPORT (5 DOOR) 2006 (8P)
i thort id post here and see if you guys could tell me if there ok or there gona rub when car is got people in the back.
Also will i be able to lower the car ?
I have an 8p A3 S Line sportback on a 55 plate and have 18" S Line 5 Spokes on it which were fitted at factory and they don't rub at all......
factory ones are 54 offset and 7.5 wide....aftermarket are 8.0 wide and 45 offset.
you could always get half ince spacers if youre worried about clearance
they may catch, depends if you are going to lower it, i have the rs6 reps on my a3, with sport setup and no rubbing at all, i will be lowering mine soon so i will let you know, also, there is a screw underneath the wheel arch which people have taken out and just doing this has stopped the rubbing issue!
