vw754
lowering advice TDI SPORT
2 posts in this topic
If i lower my a3 sport 5 door,how low can i go without affecting camber?
its already a sport so i think is 10mm lower than the standard model.
im thinking of getting 40mm apex springs or 50mm if i can ,im running on genuine s-line 18's et54 7.5jx18
Will 40 mm be ok or 50 ? any of you guys got any info,id appreciate it.
I've deleted your other thread of the same topic in the Audi Tech section. Pls avoid double posting +++
You won't affect the front camber. If you go lower than 15mm, then you'll need to consider fitting adjustable tie-bars from companies like Forge Motorsport, which will bring the camber back in line. You'll need a full 4 wheel alignment from companies like APS Homepage to get it spot on.
