gewiss1234 Posted September 20, 2009 Report Share Posted September 20, 2009 Hi can anyone help. Just got second passat and it wont pull after 2400 rpm. Symptoms are it accelorates fine to 2400 on low throttle but has simptoms of limp mode. If you floor the accelorator you get nothing. Just found out if you disengage the gears the engine revs stay where they were this is at any rev. When you dip the clutch it returns to tick over. It has th symptoms of limp mode but they normally happen over 3000 rpm. Could the crankcase sensor be at fault? Vag com shows no errors and the diagnostics seem ok? Im stuck:cool: Gewiss Link to comment Share on other sites More sharing options...
go0ne-fishing Posted October 24, 2010 Report Share Posted October 24, 2010 hi Gewiss,had same problem tracked it down to split in air hose just under radiator,check all your hoses it will probably be a split in one of them. go0ne-fishing Link to comment Share on other sites More sharing options...
