carnell Posted September 26, 2009 Report Share Posted September 26, 2009 not had much time since i picked it up Sept 1st only done 1k upto now but give her a clean today before a blast across to Blackpool Link to comment Share on other sites More sharing options...
Snoopy Posted September 27, 2009 Report Share Posted September 27, 2009 Very nice, I like the plate. Could you let me know what part of the front lights lights up with the Day Time Running Lights on the Xenon equipped car please. Is that ~ bit below the main xenon them or is that the side lights? Thanks Geoff. Link to comment Share on other sites More sharing options...
carnell Posted September 27, 2009 Author Report Share Posted September 27, 2009 (edited) Very nice, I like the plate.Could you let me know what part of the front lights lights up with the Day Time Running Lights on the Xenon equipped car please. Is that ~ bit below the main xenon them or is that the side lights? Thanks Geoff. Hi Geoff The main outside of headlight is on all the time aswell as small triangle shape light even if headlight switch is turned off, if you switch headlight switch to side lights main headlight goes off and just leaves small triangle lit up, if in auto or off position both headlight and sidelight on all the time, i read somewhere that you can chage it by holding main beam switch down for a length of time? and up to reactivate it cant remember and not tried it, If you look on centre picture running lights are on but it was a sunny day so dosnt show up that well on pic, Thanx Neil Edited September 27, 2009 by carnell Link to comment Share on other sites More sharing options...
Tarmac_Terrorist Posted September 27, 2009 Report Share Posted September 27, 2009 Looks very nice buddy Link to comment Share on other sites More sharing options...
Snoopy Posted September 27, 2009 Report Share Posted September 27, 2009 I have read DRLs can be activated/deactivated by using the headlamp lever. Ignition off. Lights to 'O'. Left turn on indicator (down) while pulling back (flashing mainbeam), switch on ignition, hold for 4 seconds or so and you should here a beep. The DRLs are now off. To reactivate is similar but you use Right turn on indicator (up) instead. Thanks for the info it clears it up for me. Thanks Geoff. Link to comment Share on other sites More sharing options...
carnell Posted September 27, 2009 Author Report Share Posted September 27, 2009 I have readDRLs can be activated/deactivated by using the headlamp lever. Ignition off. Lights to 'O'. Left turn on indicator (down) while pulling back (flashing mainbeam), switch on ignition, hold for 4 seconds or so and you should here a beep. The DRLs are now off. To reactivate is similar but you use Right turn on indicator (up) instead. Thanks for the info it clears it up for me. Thanks Geoff. Thought it was something like that, i will have to give it a try, car was certainly turning heads down the golden mile at Blackpool last night and getting plenty of thumbs up Link to comment Share on other sites More sharing options...
chriswastle Posted September 28, 2009 Report Share Posted September 28, 2009 Looks Fantastic, you have still got a job to beat Red or White on the GTI. Link to comment Share on other sites More sharing options...
carnell Posted September 28, 2009 Author Report Share Posted September 28, 2009 Looks Fantastic, you have still got a job to beat Red or White on the GTI. I was going to go with white but in the end went back to red, deffo best 2 colours that suit the mk6 I had a red mk5, then blue Mk5 R32 now back to the fastest colour red......... Link to comment Share on other sites More sharing options...
