330dcoupe
More noise required!
48 posts in this topic
hello chaps..
I'm looking for some advice about getting some better noise out of my GTI. I've done a bit of research and most people are advising Milltek - but for me, they're very expensive and ideally, I'd only like a highflow cat down pipe and some wider tailpipes. Let's leave the tailpipes to one side for a moment and concentrate on the down pipe. I've read a 3" downpipe, which can be provided by many suppliers, would need certain mapping software (stage 2 AMD) in order for the 'exhaust light to be knocked off'...is this true? Sharky?
Ideally, the cheapest (used or new..i'm not fussed) is what i'm looking for - for some better noise.
something like this (YouTube - MKV GTI 3" ATP Downpipe with 3" Autotech Cat-Back) would be ideal...but i can't work out whether or not he has a different back box too.
thank you in advance.
I forgot to add, my GTi has been remapped by an independent 'mapper' and has more HP than what AMD and Revo provide at 'Stage 1'. (well, that's what he said :P)
At the end of the day there's a limit to how good you can make an in line four sound. And that limit is called Cosworth.
If you really want your Golf to sound better your best option is to swap your GTI for an R32. :P
Any decent remapper can remove the check engine light caused by removing or fitting a lower efficiency cat.
BTW, if your remapper told you that you have more power than the figures quoted by the two tuners you mentioned, I can tell you that he was definitely lying :)
Amen to that, Brother. +++
Putting the noise to one side for the minute - what are you after? More torque and power, looks, sound, or the cheapest exhaust possible?
As for the remap - if it's a Mk5, with a remap, there's a cap to what you can reliably (and reliably is the key) get the standard 2.0 TFSI engine up to. Too many independent tuners just over-fuel the car, or under-fuel it, so you get a bang of torque and it feels fast, but they don't take any account of air fuel ratio or exhaust gas temps.
It's a shame that you don't want to fork out for a Milltek. A Non-resonated Milltek on a MKV GTI sounds great. Not as good as the V6 clearly, but still worthy and noticeable +++
How about folding your rear seats!!:-)
Dont mean to sound flippant, but anytime i have to carry anything in the car, it takes me a few days to put the rear seats back up again........ sounds brilliant with them down
Mook, I'm not after anymore power...just a better rumble from the engine!
Garcon, why would I want a slower, thirstier & heavier car? no thanks..... ;)
sharky, he definitely can.
Because you want something that sounds better than a 1.6 Astra? :grin:
....Some advice from The Fruit 'n Fibre Man: If you are talking about more 'noise' from inside when driving as opposed to screaming at everyone on the pavement and other cars, then : -
- Remove the bonnet insulation.
- Get an aftermarket high-flow tubular air intake (EVOMS is the loudest but Forge Twintake and ITG offerings add significant neddies, but subtle sucky soundz).
- Get aftermarket engine mounts - Full set of 3 - The lower mount helps getting power down but the sides transfer a glorious Grrrrrrrrr!! in direct harmony with the exhaust.
- If interested in a Milltek you could ask them to supply you the same system as mine (but not quads) - Very shallow VWRacing style back box. Dave Marshall (Factory Manager) and Phil Millington (MD) know me well and will know what you're referring to.
Thanks RR :)
I tell you what made me really want some more noise - I heard some geezer pull away in a Focust ST at low speed and it made a lovely rumble (car seemed stock) and I just wish I had a little bit more of that. So something a little meatier but still very much in the 'grown up man's hot hatch' gategory - SAY NO TO CHAVINESS :D
The insulation idea is new to me...wouldn't that cause any vibrations to the bonnet?
Yes but the ST has a proper engine in it, with a proper amount of cylinders that you'll just never replicate or indeed get close to with a 4-pot :(
....I only had the steel bonnet without its insulation lining for a few months and then changed to a carbonfibre bonnet (painted on the outside). Neither bonnet have any vibrations.
Aftermarket engine mounts transfer some very minor vibrations which I would describe more as a buzz vibe.
"a buzz vibe"
Hmmmm.....
You do get a lot of 'pleasure' out of your car don't you, Robin :)
"a buzz vibe"
Hmmmm.....
....I most certainly do! I'm now also enjoying the sucky-sucky noises she's making due to my new Forge Twintake air intake (and the hike in extra power).
Unless it's a flat boxer 4 pot. +++
But that would involve arguable more complicated work on your GTI engine than adding a cylinder or two! :roflmao:
But Subaru have ruined it on the latest gen Impreza - equal length manifold my arse. Bring back the burble :(
True, certainly for the Jap spec engine. There's still a decent noise to the UK spec 2.5 (especially in Prodrive tweaked 330s spec), but it's not quite the glorious offbeat bass burble of a free breathing Mk1. +++
They don't burble any more - they just shout. P1 for me please :D
I'll call round in mine sometime. It still burbles, it just doesn't sound like it's running on three. +++
Two options..... buy a milktek exhaust or buy a V6, V8, V10 or V12 engine, depends on the noise your after.
Riz :)
V10s sounds best, followed by flat 6s, then V8s, then I'm not sure.
Wrong, wrong, wrong, wrong, wrong :rolleyes:
Flat 6
Howling V10 (F1 of old)
V8 (flat plane crank - e.g. Ferrari)
V8 (of the burbling kind)
:D
