DHA
Cold weather starting problems
29 posts in this topic
Since the weather has turned cold in the last week or so, my GTI has struggled to start on occasion. It turns over, so not a battery issue I don't think, but on the first attempt it doesn't turn enough to get the engine started. So far it works on the second attempt.
Any ideas, or is it just the cold?
Definitely sounds like battery. The Mk5 GTI battery is tending to last about 4 years. You have the choice of a long slow recharge or a new battery with a new warranty on it - My new one is a VW battery with I think 3 years warranty (certainly 2 years).
The problem with a recharge is that you never really get 100% reliability and unless very regularly recharged you'll find yourself unable to start at all one day, as I did recently with somewhere important to drive to.
3yrs 50,000 miles is what I have done on it. I mainly do journeys of over 45 mins so surprised it has not been charged up that well.
3-4 years is the expected life span of a battery.
I keep mine on a battery conditioner. Started instantly after not run for 10 days still.
I reckon it could be a weak battery; if not a fragile coil pack.
Interesting I have just found this post. I have had exactly the same issue and mine is now 4 years old. There is a green light showing still on the battery but from time to time it needs a second go on turning it over.
Just out of interest has anyone taken the battery off and given it a full charge? Anything to be aware of? Alarm going off/imobiliser?
Also where did you get your new one from?
Thanks+++
Another +++ for battery.
Last year the S3 started to cut out on first start if not revved a little for first 10 seconds or so, and then was fine.
About a week later battery totally died. Charging could not recover it.
Bought a new battery from Halford's and its been fine ever since.
i had this problem with a previous car -AA fella gave some good advice.
New modern batteries are sealed units, but will eventually loose water thro the seals.
The seals can be prised off with a screw driver and each cell topped up with distilled water and recharged.
Once re charged, the will last a bit longer
Might be worth checking first, i thought the maintenance free batteries had a gel electrolyte and not the distilled (or tap water...as we all used) water in the older type and non-maintenance free types.
Maybe you can just top up with water but it might be worth checking first - im personally not sure but would tend to think avoid.
Cheers
Paul
Sorry for laughing Dave but I thought you might like to know that the Trev has started first time, every time in this cold weather :roflmao:
(The fact that it hasn't left the safe confines of the garage or neither here nor there!)
....You should be aware that if your car is remapped, it will revert back to 'stock' (or simulated 'stock') performance each time your battery is disconnected. Having Revo I am able to switch back to 'Performance' settings via the OBD port.
Bravo! :roflmao:
my GTI
Didn't know you had a GTi Dave..... or have I missed something?
Wondering about one myself.........Only owned Audis for the last 25 years tho' !
The guys at Martins Vw in Camberley were pleased to see me a month or so back when I called in..... they used to work at Whites Audi.... where I have spent far too much money over the years ........
Have had it for 3 years Chris!! :) it's been a great car if I am honest hence why I have kept it so long. It was to replace the porsche when we moved to an NCP carpark at work. It does the job pretty well, the reason I have not moved on is what to replace it with without spending a lot of money for a better car.
....Indeed it is a great car - An excellent allrounder. When modified it becomes even more difficult to know what to replace it with unless one goes for a different kind of vehicle such as a Porsche etc.
On the subject of the cold weather, the turbo loves it! Performance is very crisp.
+++:cool:+++
DHA, this made me go out and try to start mine today!
It's been sitting in the garage for nearly 3 weeks.
I'm very pleased to say that it started first time :-)
The battery is just over 3 years old now.
I had the original battery and alternator replaced under warranty after about 6 months from new.
The battery kept going flat after only 3 or 4 days without the car being used.
Apparently the original and the replacement is one of these "gel" things.
I hope you get your problem sorted out soon.
Ludwig
I remember the Porsche going because of the car park business but hadn't realised that you had got a GTi.....
I think you turned up at Virginia Water in a Cooper S Works on a couple of occasions
( Hers isn't it ? ) so I then lost the plot ..... : o
lets face it three years for your car is a long time, do you know about MOTs ..... : )
Is yours a manual, I think Robin's is DSG ?
Robin -You still please with the diff you had fitted to yours? Does it make any worthwhile difference in the snow?
+++:cool:+++
Totally agree. The DSG is also superb in the snow. If your are spinning in a gear just paddle change to a higher gear with no uninterrupted power delivery and it just gets grip and goes.. Also from a standing start you just take your feet off the pedals and it just starts off by itself. +++
I was shocked how much they charge for them!!!! :roflmao:
Ludwig
Yesterday went to visit some friends, 3 hour journey then car sat for 5 hours. It struggled to catch but did after a few turns of the starter. Might pop past the dealer but I reckon it could be a costly experience whilst they "diagnose" it!
Interesting to hear that, good, as I think we've decided that the next car will be DSG Stronic or whatever they wish to call it.
But I can also do that in our manual equipped cars : )
I do have to concentrate a bit but I suppose it's so much easier with DSG
If all these mumptys out on the roads could do this as well perhaps they wouldn't be stuck so often..... 4k on the rev counter with wheels spinning, they seem to think if it doesn't move it needs more revs.....
....I'm extremely pleased with my Quaife ATB diff. I've had it over a year now but haven't seen snow since February 2009. It's not going to work like 4WD does in the snow but every little bit helps. I won't drive if it's snowing - I hate the stuff!
DHA, a 3 hour trip should have charged the battery up I would have thought?
So a call in to the dealer is the bet be I agree.
re. "Might pop past the dealer but I reckon it could be a costly experience whilst they "diagnose" it! "
Yup, 'fraid so.
I recall that they had mine for over 2 days doing "diagnostic tests" before they found out it was a duff battery and alternator!
Luckily, it was under warranty, as I said.
Keep us posted on developments please.
Ludwig
MM, the padle tip sounds like a very good idea, thanks.
I'll try it next time I'm out.
Something else they don't tell you in the handbook!
re. "a standing start you just take your feet off the pedals and it just starts off by itself. "
I've noticed this too - the grip it gives is uncanny!
Ludwig
There is a software update for 2.0TFSi engined cars that should solve this, it depends on your current software revision and if it's ever been updated by your dealer. Worth a call to them to ask, I guess they should do it for free.
