vw754
Audi a3 tdi (8p) fault code...strange behaviour
2 posts in this topic
soon as ignition is on or car is started air-con fan kicks in coming on and off randomly.
Battery light flashing and handbrake light flashing and Dash clocks light up and then die on me.
All gauges and lights dont work then they flash on and off intermittently just this 1 fault
18043 powertrain data bus missing message from A/C controller p1635--000--
AUDI A3 2.0 TDI (8P)
Tuesday,19,January,2010,19:51:20:18030
VCDS Version: Release 908.0
Data version: 20090911
Chassis Type: 1K0
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 56 62 72 7D
VIN: WAUZZZ8P95A134457 Mileage: 133110km/82710miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 0010
08-Auto HVAC -- Status: Cannot be reached 1100
09-Cent. Elect. -- Status: Cannot be reached 1100
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: Cannot be reached 1100
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: Cannot be reached 1100
44-Steering Assist -- Status: Malfunction 0010
46-Central Conv. -- Status: Cannot be reached 1100
47-Sound System -- Status: OK 0000
52-Door Elect, Pass. -- Status: Malfunction 1110
56-Radio -- Status: Malfunction 0010
62-Door, Rear Left -- Status: Cannot be reached 1100
72-Door, Rear Right -- Status: Cannot be reached 1100
7D-Aux. Heat -- Status: Malfunction 1110
Address 01: Engine Labels: 03G-906-016-BKD.lbl
Part No SW: 03G 906 016 FF HW: 028 101 190 5
Component: R4 2,0L EDC 0000SG 6337
Revision: 12345678 Serial number: AUX7Z0E1FNG04N
Coding: 0000072
Shop #: WSC 06314 000 00000
1 Fault Found:
18043 - Powertrain Data Bus: Missing Message from A/C Controller
P1635 - 000 - -
Freeze Frame:
RPM: 0 /min
Torque: 6.0 Nm
Speed: 0.0 km/h
Load: 0.0 %
Voltage: 12.16 V
Bin. Bits: 00000100
Bin. Bits: 00000000
(no units): 144.0
Readiness: 0 0 1 0 1
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0023174
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 08: Auto HVAC
Cannot be reached
Address 09: Cent. Elect.
Cannot be reached
Address 15: Airbags Labels: 8P0-959-655-94.lbl
Part No SW: 8P0 959 655 C HW: 8P0 959 655 C
Component: Airbag 9.41 H10 3230
Revision: 91H10323 Serial number: 003620028UHP
Coding: 0034622
No fault code found.
Address 16: Steering wheel
Cannot be reached
Address 17: Instruments Labels: 8P0-920-xxx-17-MY7.lbl
Part No SW: 8P0 920 981 A HW: 8P0 920 981 A
Component: KOMBIINSTR. VDO H73 0300
Revision: D04 Serial number: 2241ED04006344
Coding: 0004443
Shop #: WSC 00047 210 62144
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 D HW: 1K0 907 951
Component: Gateway H08 0100
Revision: 08 Serial number: 2500105208043E
Coding: 3D3F0B42072103
2 Faults Found:
01336 - Data Bus for Comfort System
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 86
Mileage: 133116 km
Time Indication: 0
Date: 2010.01.18
Time: 23:02:13
00470 - Combination comfort Databus in Single Wire
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 46
Mileage: 133116 km
Time Indication: 0
Date: 2010.01.18
Time: 23:03:49
Address 25: Immobilizer Labels: 1K0-920-xxx-25.lbl
Revision: D04 Serial number: AUX7Z0E1FNG04N
Shop #: WSC 00000 000 00000
Address 42: Door Elect, Driver
Cannot be reached
Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.7 1502
1 Fault Found:
00750 - Warning Lamp
013 - Check DTC Memory - Intermittent
Freeze Frame:
Mileage: 3080 km
Temperature: 26.0°C
Voltage: 13.10 V
Voltage: 12.90 V
Address 46: Central Conv.
Cannot be reached
Address 47: Sound System Labels: 8Px-035-382.lbl
Part No SW: 8P4 035 382 HW: 8P4 035 382
Component: AB2 SUBWOOFERBOXH03 0180
Revision: 00002 Serial number: 10000001230153
Address 52: Door Elect, Pass.
Cannot be reached
Address 56: Radio Labels: 8P0-035-1xx-56.lbl
Part No SW: 8P0 035 186 C HW: 8P0 035 186 C
Component: concert II EU H51 0100
Revision: 01S Serial number: AUZ2Z3E2059450
Coding: 0001001
Shop #: WSC 06435 000 00000
1 Fault Found:
00466 - Control Module for Steering Column Electronics (J527)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 254
Reset counter: 86
Mileage: 133092 km
Time Indication: 0
Date: 2010.01.18
Time: 21:07:25
Freeze Frame:
Bin. Bits: 10
Address 62: Door, Rear Left
Cannot be reached
Address 72: Door, Rear Right
Cannot be reached
Address 7D: Aux. Heat
Cannot be reached
End ---------------------------------------------------------------------
