Paul_GTI
MK5 GTI Engine Light Help - Again
5 posts in this topic
Hi Everyone
Had the cambelt changed on my 05 gti along with having the car serviced today. Anyway everything was fine inslow moving traffic then once i hit the motorway car felt under powered (revs taking much longer than usual and slow acceleration).
As soon as i got the car on my drive the engine light comes on!!
Anyone experienced this previously??? or have any ideas what the issue may be?
Thanks
Paul
It could be a few things - fault coil packs and lambda sensors are common causes.
You need to get it hooked up woth VagCOM or the VAS system at a dealer to find out what the cause is.
thanks for that got the AA coming out to have a look - is this something they could diagnose?
Yeah, I would expect so.
If it turns out to be a coil pack ask the AA chap to tell you which cylinder it is then go to the dealer and buy one yourself. VW charge somethign stupid like £90 to fit a replacement coil pack but it's a doddle to go it yourself.
