markcnash Posted January 27, 2010 Report Share Posted January 27, 2010 It seams as there are many others out there with the same problem as I have around the buttons on my climate control unit rubbing off which in day light looks bad but at night looks a whole lot worse. Is there any kit for repair for this or is it best just to replace the whole unit Whats the top tips here Thanks Link to comment Share on other sites More sharing options...
S4_marv Posted January 28, 2010 Report Share Posted January 28, 2010 Slightly different to your problem, but a couple of mine seem to stick. Worse when it's cold. I guess a previous owner spilt something sticky down his centre console (I dread to think...). But I'd be interested to know if there's an easy way to replace buttons, or even to remove them to clean. Link to comment Share on other sites More sharing options...
benjie Posted January 28, 2010 Report Share Posted January 28, 2010 Entirely new replacement unit needed from what I've read I'm aftaid. I got a new one for £40 from ebay, quite a steal I think. Be aware that 2001-2008 A4's use the same climate unit (as well as the 'New' SEAT Exeo!), so there should be loads about. If you get a unit from a Nov 2004 onwards car you will need to solder a relay into the back (I have fitting/wiring instructions) as the interior design changed a little. Link to comment Share on other sites More sharing options...
markcnash Posted January 29, 2010 Author Report Share Posted January 29, 2010 Thanks for that Best start looking through ebay then I thought there may off been a paint option As for the sticky buttons - the cup holder is above so could be anything Ive had the same on the CD player, I just sprayed some wd40 around it and its fine now Link to comment Share on other sites More sharing options...
benjie Posted January 30, 2010 Report Share Posted January 30, 2010 That's ok. It may be worth a check with Audi to see if they do do the buttons, as things can change. Link to comment Share on other sites More sharing options...
