kaitechno
Fabia vrs fuel consumption problem
9 posts in this topic
I wonder if anyone out there can help.
I've just bought a 3 year old fabia vrs and having had it for long enough have realised I only get about 345 miles out of a full tank and I'm sure I should get about 450ish out of it.
I've just had it checked for any leaks and had it serviced(new oil/air/fuel filters, although done at an independent garage)but made no difference. I've also had it in the Skoda Garage to run a full diagnostic and nothings come up.
The mpg gauge reads out at about 47mpg but in reality I'm only getting about 36mpg.
According to Skoda 'there's nothing wrong with it'. I corrected them in saying 'there is something wrong with it you just can't figure out what it is'.
Has anybody, in their infinite wisdom, have any ideas what it might be. I've been left scratching my head...
It could just be down to your driving style. Lot's of stop/start short journeys?
The average mpg figures on the computer tend to be a bit optimistic as are the figures quoted by the manufacturer.
Cheers for the reply, although I'm fairly sure it's not this.
I am a driving instructor and had a Skoda Fabia before this one(albeit a comfort 100bhp) and I used to get 460miles out of a tank with that one and the mpg gauge used to average about 44mpg. My driving style hasn't changed at all.
It's a proper puzzler this one
Having done a bit of research I have found out that a faulty MAF(i'm no mechanic so don't quite understand what this is) can affect the fuel consumption. Does anybody know if this can be faulty but still come up ok on a diagnostic? Some info about an Audi with the same engine and same problem seems to suggest that it can...
Yes a MAF can be faulty and not log a fault. They can be cleaned or replaced for around £80.
It simply monitors the air going into the engine so the ECU knows how much fuel to inject. Pretty common fault on VAG cars although you normally notice lack of power, poor running when the MAF is faulty
There's no noticeable loss of power although it does shudder a bit at idle sometimes. It also coughs sometimes when I come off the gas pedal to try hold my speed although I can never get it to do it when I mean to.
I'll get someone to have a look at it. Thanks for the info +++
Have you checked the fuel consumption using the brim to brim methed?? I find my vrs very accurate but my friends is rubbish. Both cars return around 40mpg day to day and high 40,s on a run.
It sounds like it might be my mpg gauge more than anything then. I've brimmed it quite a few times now and run it down until the 'miles left in the tank' meter runs to 0. I've been getting just shy of 350 miles out of a tank which works out at 36.5mpg. Does this sound about right for this time of year with winter fuel? Any idea how many miles you or your mate normally get out of a tank? And any idea if possible to recalibrate a dirty, low-down lying mpg gauge?:(:) P.S. Is yours remapped at all?
My old Ibiza 130pd would only do less than 40mpg if it was driven like I stole it. All other times it would be 45+. I think 38mpg is achievable at 100mph with a roof rack and a mountain bike on the roof.
