fab5paddy
Intermittent Windscreen Washer
3 posts in this topic
Hey,
Has anyone had this issue? My window washer is working intermittently one day its fine the next nothing??? Washer bottle is full!!! Is there a sensor or something? Or is my car concerned about water conservation
:roflmao::roflmao:
Cheers
It's probably the fan jets getting blocked. Are you using VW screenwash?
Many claim that other makes of screen wash can cause blocking of the jets; a subject which has been debated long and hard on other forums with strong differences of opinions.
I believe they are easy to remove and clean in warm water, or alternatively you can buy new ones and have change from a tenner.
Thanks for the feedback Tarmac!
Did a bit more fault finding on the issue myself, when the washer arm is pulled its like there is no power suppling the pump but when pushed forward the rear pump works, maybe a micro switch on the jets, and cuts the power to the pump! the wipers work fine!!!! Aaaagh:mad:
