m0nkeygirl Posted March 26, 2010 Report Share Posted March 26, 2010 hi, ive got a mk3 golf 2.0 that is giving me huge headaches, drives like a dream 50% of the time the rest it judders when i take my foot of the accelerator, when slowing down at junctions etc it either idles perfectly one minute or judders like crazy then stalls, took it to a garage who said it was the oxygen sensor, had that replaced still the same problem, then had the air flow meter changed,didnt solve the problem so i went to another garage who put it on a diagnostic machine and changed the temperature sensor, and surprise im still have the same problem.....HELP! Link to comment Share on other sites More sharing options...
meixsellboi Posted April 13, 2010 Report Share Posted April 13, 2010 buy a can of MAF sensor cleaner (mass air flow) and try clean your MAF sensor, its located right next to your airfilter, running along the airhose to your throttle body, if its dirty, it could send the wrong information to your ecu, and cause your problems the link below is a picture of your MAF sensor, completely remove it from your car, and then use the cleaner on it, allow it to dry, re-secure it to your car, and dry driving it now, and let me know how it works. http://www.pgautosale.com/catalog/125001.jpg Link to comment Share on other sites More sharing options...
m0nkeygirl Posted April 14, 2010 Author Report Share Posted April 14, 2010 thanks will try that tomorrow, the car has now been to the garage about 10 times, had the oxygen sensor,maf,ecu,temp sensor, hoses and now the throttle body changed and still the same problem, luckily ive managed to return the ecu and throttle body as these werent faulty, im losing the will to live with this car!!! Link to comment Share on other sites More sharing options...
cruiser647 Posted April 15, 2010 Report Share Posted April 15, 2010 Might also be worth cleaning the throttle body with Carb Cleaner (available from Halfrauds). Spary in loads (engine off) let it soak for a while and then start the engine in a few minutes. Lots of smoke. Then when the engine is warm, spray the stuff in with someone revving the engine. Link to comment Share on other sites More sharing options...
m0nkeygirl Posted April 19, 2010 Author Report Share Posted April 19, 2010 cleaned the maf sensor, throttle body, and the garage checked the car over again and said it might be the crank sensor, but they couldnt find one on my car, everyone is now at a loss, vw and the other 3 garages i have taken the car to have no idea what is wrong with it, i dont know what to try now or where to take the car, the only option i can think if is to change the engine completely, anyone got any other ideas???? Link to comment Share on other sites More sharing options...
Scarface247 Posted March 16, 2012 Report Share Posted March 16, 2012 I have recently bought a mk3 golf Gti and I am starting to pull my hair out with the running problem it has. It splutters under load, randomly, sometimes fine sometimes awful. It ticks over at about 900rpm and sounds fine but when I'm driving it seems like it has a misfire and the loss of power is drastic. Annoying as I love the way they drive when good. I have replaced the following; Spark plugs (ngk) Ignition leads (gsf) Distributor cap Rotor arm lambda sensor breather pipes air pipes all over cleaned throttle body coil also had the timing checked I have had it diagnosed by a garage and they are telling me that it is showing the sensor in the distributor is faulty, I just don't want to through any more money at it with out knowing. It's really getting to me. HELP !!!! Link to comment Share on other sites More sharing options...
shao_khan Posted March 16, 2012 Report Share Posted March 16, 2012 Welcome to tyremsoke. Try askign this over on clubgti.com they have a lot mroe knowledge in the forums on these engines than we do. Keep us posted how it goes Link to comment Share on other sites More sharing options...
Tipex Posted March 16, 2012 Report Share Posted March 16, 2012 Had similar issues on an Audi Coupe Quattro, and it turned out to be the Hall Effect Sensor on the distributor. Only a cheap part so well worth changing if it's the same sensor your mechanic diagnosed. Link to comment Share on other sites More sharing options...
Scarface247 Posted March 16, 2012 Report Share Posted March 16, 2012 Thanks guys, I have a thread going on clubgti already and it seems to be working. I think it's going to be the hall sender. Link to comment Share on other sites More sharing options...
