gypsyboy
oli level warning!
4 posts in this topic
hello did 2 miles yesterday and the above started to flash on my dash.
stopped to check and the level was at the bottom of the stick.
i bought some oil and correctly topped up.
the warning light is still bleeping on my dash annoying me now.
i thought it would have gone off after topping up.
any ideas please?
passat 2002 tdi
The oil light has two warning functions I believe, one is oil level, the other is oil pressure, one of them flashes, can't remember which though, I'd get it checked out asap, just don't drive it if it is low oil pressure.
hello i have checked manual and it is indicating level low.
just topped up again to make sure but still bleeping saying check level.
is there a chance the bonnet sensor is knacked?
hi i had this problem a few weeks ago i checked everyhing and went round to m mate who specialised in vw's he opend bonnet and checked the wire which tells u that the bonnet is open and tht was loose, he said its a common fault and the light stays on because the somputer didnt register that i had opened the bonnet, hope that helps
