ghl Posted April 15, 2010 Report Share Posted April 15, 2010 Where is the egr valve.on vw caddy 04 2.0 sdi Address 01: Engine Labels: None Control Module Part Number: 03G 906 016 GP HW: 028 101 154 1 Component and/or Version: R4 2,0L EDC 0000SG 7001 Software Coding: 0053031 Work Shop Code: WSC 00976 209 66252 1 Fault Found: 17848 - EGR Valve (N18): Open Circuit P1440 - 000 - - Freeze Frame: RPM: 840 /min Torque: 30.0 Nm Speed: 0.0 km/h Load: 0.0 % Voltage: 14.29 V Bin. Bits: 11000100 Mass Air / Rev.: 250.0 mg/str Mass Air / Rev.: 0.0 mg/str Readiness: 1 1 0 0 0 so i am tryin to find out what the part number is so i can order it and find out which one it is as when i went to vw they said iit could be 1 of 2 as thier is another is a sensor or something .ANY HELP THANKS Link to comment Share on other sites More sharing options...
Mook Posted April 15, 2010 Report Share Posted April 15, 2010 Try VagCat for the part number - you need to register with them and then go to Catalogue and run a search Link to comment Share on other sites More sharing options...
ghl Posted April 15, 2010 Author Report Share Posted April 15, 2010 Ok thanks Link to comment Share on other sites More sharing options...
vwsteve Posted April 16, 2010 Report Share Posted April 16, 2010 hi if your engine code is BDJ then there are 2 components in the egr circuit 1 is the egr valve part no 038 131 501c 2 is the pressure converter valve patr no 1j0 906 627c hope this helps Link to comment Share on other sites More sharing options...
