Evoracer
Mini Engine problem
2 posts in this topic
Hello first and foremost,
going by the name you might be able to guess I own a mitsubishi Evolution.
by my problem lies with a bloody mini (partners) 2002 cooper s
I was driving home from football in the mini and I could hear a draging noise so trying to establish what was up with it I realised it was only when the engine was under load accelerator pressed. After a while I heard a big thump then a plume of smoke from the exhaust I got it home as this happened just arround then I corner then started to investigate cylinders 1 & 2 not fireing when i pulled the plugs out the plug in 2 has been hit by something. i have worked/played around with Evos for years so theres me thinking lets get it striped down and have a look so thats what i started to do but the mini having a pain in the arse engine today i've given up got alot strpipped off charger cooler whole front end the charger cooler was full of oil so to me i think the charger has let go and sent bits into 1&2
any thoughts also anyone know any specialists in kent as i've had enough
regards Kieran
Welcome to TSN
I haven't got a clue, and there are not many Mini owners on here.
Sorry.
I am sure someone will be along who can advise.....
Good luck Kieran, and if/when you find out what it is, can you let us know too?
