ken Posted May 7, 2010 Report Share Posted May 7, 2010 Hi, I need to remove the rear springs on my 2007 tdi estate,can i just remove the bolt on the stub axle end of the trailing arm and jack it down or is this the wrong method?Also will the camber adjustment still be ok,as this is at the other end of this arm(link)? The reason for removal is that i tow a caravan and the springs are fairly soft,so i intend to add air assist bags inside the springs which can be inflated when towing. I tried to obtain self leveling suspension but could not find any for my passat. +++Ken. Link to comment Share on other sites More sharing options...
