allanon_1980 Posted May 22, 2010 Report Share Posted May 22, 2010 Hi guys, Traded in the 335d for a Boxster S. What should I use to clean the fabric roof?? Can I just use my Meguiars car shampoo or do I need special cleaning stuff? Cheers guys. Link to comment Share on other sites More sharing options...
steelwind101 Posted May 22, 2010 Report Share Posted May 22, 2010 Hello Do you mean clean as in every week? If so then you can just wash it with the rest of your car. There are various dedicated cleaners out there from the likes of 303, Autoglym or Meguiars which can be used 3-4 times a year to ensure the fabric is clean. Some people use an APC (all purpose cleaner). Appling a protector after using a dedicated product is a good idea. Using a protector will help stop rotting, staining etc. Cleaners and protectors come in twin packs often. Geoff Link to comment Share on other sites More sharing options...
OGWT Posted May 31, 2010 Report Share Posted May 31, 2010 Road dust and dirt settles on the fabric weave, water and dirt act as an abrasive and if left will break down the fibres and abrade the stitching. There should be no need to wash your fabric top every time you wash your car. Each time you wash, even with the gentlest car wash concentrate: you are removing the previously applied protection. Just vacuum the top using a brush attachment to remove loose dirt and then rinse with plain water, blotting dry with a Microfiber waffle weave towel There is a lot of misinformation about protecting convertible fabric tops; if your goal is maximum protection, do not use water beading/sheeting as an indicator, as its caused by surface tension; while it’s true that it is a visual indicator that the protection previously applied is still present it does not guarantee that it’s actually providing protection. “If water beads on the surface it’s protected and able to repel stains” (Just like water beading on a paint; it’s due solely to surface tension) the answer to both is - No The waterproof protection you get from a convertible top comes from the butyl rubber core sandwiched between the outer canvas and the inner pre-shrunk cotton layer. An applied protection only renders the fabric water resistant. You don't have to wash your car's top every time you wash your car, but used occasionally it will remove ingrained soil /road dirt. Every time you wash your convertible top, even with the gentlest car wash shampoo, you are stripping off any previously applied protection. A better methodology would be to vacuum the top using a brush attachment to remove loose dirt and then just rinse the top with clean water. Rode & Schwalenbert Global Minority Business Network (GMBN) Germany the world leading manufacturer of automobile convertible tops exclusively recommends Harrtz RaggTop Cleaners and Protectant. Developed specifically for cleaning, re-proofing and preserving convertible tops, these cleaning kits consist of two products: 1. Cleaner to remove soiling, stains and atmospheric pollution for both natural and synthetic materials. The best cleaners are formulated from low-pH (low alkalinity) and gentle enough for repeated use over years. They will rely on proteins and enzymes for their safe, but effective, cleaning power. 2. Fabric protector to re-proof and preserve fabric tops from the effects of water absorption, surface soiling and staining, and provide a sunscreen from UV radiation and subsequent fading, and it repels dirt, grease, and oil. It doesn’t make your vinyl top glossy or greasy-looking. It will have the natural matte sheen of new vinyl. Alternative product 1. This is the fabric protector recommended by Glen Raven Mills (Sunbrella) and the Harrtz Corporation, 303™ High Tech Fabric Guard restores lost water repellence and stain repellence to factory new levels. It stops leaks, resists soiling and impedes mildew formation and helps protect against the sun's harmful UV rays. Application Methodology • Masking - use a 1-mil x 9-foot x 12-foot plastic drop cloth, cut it in two pieces (6 x 9-feet). With the convertible top up in front & back, drape one piece across the back as close to the top hinges as possible. Drape the second piece over the windshield and far enough 6-foot h back to cover the seat back, fold the convertible top down but do not latch. Mask the areas around the fabric top with masking tape (3M® Painters Easy Release Blue Tape) • Mask the rear window - cover the rear window to avoid over-spray • Use a soft horsehair brush to remove any loose surface dust, use a lint lifter to remove lint from the fabric surface. Be careful around the rear window to avoid scratching Cleaning the Fabric Top - shake product for 30-60 seconds to ensure even mixing • With all cleaning products, always test a small, indiscrete area first to ensure it won't discolour or stain the surface, and ensure that the pH of the product is suitable for the material. • Apply fabric cleaner (Harrtz RaggTop Cleaner) with a clean, damp applicator and leave to penetrate fabric for 10 – 20 minutes dependent upon stain. Gently scrub using a soft brush to get into the texture of the fabric. Work the brush from the middle towards the outside. • Repeat if necessary; applying two light coats are better than the application of one heavy coat: allow drying thoroughly between coats. • Rinse off using a low-pressure water hose and a soft horsehair brush • Dry with a waffle weave Micro fibre towel using a blotting motion to dry excess moisture. • Allow the fabric to dry for as long as possible (preferably 24-hours) before using the protectant. An hour or two isn’t long enough, it may feel dry but that’s only the uppermost surface layer (using a protectant on a damp fabric will ‘seal in’ the moisture and encourage the formation of mildew) • Apply a fabric protector (Harrtz RaggTop Protectant or 303™ High Tech Fabric Guard ) on the dry fabric, keeping about 6-8 inches above surface and using a back and forth movements spray lightly but do not soak (if you use too much product it will turn white, rinse away excess and allow to dry) • Always ensure that the stitched seams have adequate protection applied to them • Alternatively use a soft horsehair paintbrush and apply light thin coats, if time permits, two light coats are better than one medium coat, using gentle sweeping motion. Do not saturate. Allow to dry 10-15 minutes between coats, and to dry thoroughly before using or storing. • Remove all masking tape and any other materials • Be sure to remove any accidental over-spray from paint or glass surfaces immediately with a damp Microfiber towel or a 1:1 isopropyl alcohol / distilled water solution. On paint work use a pre-wax cleaner if necessary or fine detailing clay. • After treatment the top will bead water, when the beading diminishes (usually at 6 monthly intervals, dependent upon climate / use) it's an indication that it's time for another treatment. Maintenance- normal cleaning: use a medium pH car wash concentrate and apply UVR protection; periodically (dependant on climatic conditions) as its protection degrades over time, apply a UV protection (303™ Aerospace Protectant) to fabric by keeping spray about 6-8 inches above surface and using a back and forth movement spray lightly but do not soak fabric. Apply a fabric protector (Harrtz RaggTop Protectant) each quarter (adjust for use / and or environmental conditions) Stains Mould / Mildew - dirt and moisture are essential to mould / mildew propagation; if the contamination is not removed the fungus will degrade the material. Just like mould and mildew contamination in other areas, you cannot wash or shampoo it away; this only makes the problem worse. The fungus is caused by living organisms that must be killed before the material is cleaned, and all the moisture is eliminated by thoroughly drying the material or the mildew will return a) Use a medium soft brush and a 4:1 solution distilled water / ammonia and then rinse with cool clean water b) For tougher stains use a mixture of one (1) one teaspoon ammonia / quarter (1/4) cup Hydrogen Peroxide / three (3/4) cup distilled water and then rinse with cool clean water Badly stained material - Wet the area to be cleaned with distilled water plus (a) or (b) above, lightly spray and rinse thoroughly. For neglected convertible fabric tops leave above solution fabric cleaner on overnight, keep damp by covering with a plastic sheet, once stains are removed rinse thoroughly and apply protection. Bird Excrement - this product will remove it without damage to both vinyl and cloth it will not harm its water repellence. Poop-Off Bird Poop Remover is a non-toxic, biodegradable, active enzyme formula that removes droppings and residues composed of all types of avian diets including, seeds, fruit, nuts, meat, vegetables, nectar, bugs and grains. Originally a marine product, it will not harm the tops water repellence Link to comment Share on other sites More sharing options...
Rachel Posted June 2, 2010 Report Share Posted June 2, 2010 great post! Where were you when I still had my ragtop? Link to comment Share on other sites More sharing options...
OGWT Posted June 3, 2010 Report Share Posted June 3, 2010 great post!Where were you when I still had my ragtop? I've been detailing since I was fourteen (five decades +) but living in US and therefore answering questions for the last twelve years or so on detailing forums. We must have kept missing each other Link to comment Share on other sites More sharing options...
