shrimpos Posted June 6, 2010 Report Share Posted June 6, 2010 Hi Can anybody help The central locking is playing up on my wifes golf. When you lock the drivers door the front passenger door does not lock all the time. if you turn the key a couple of time it will eventualy lock and the led will start to flash. I have changed the passenger door lock but still the same. Does anybody have any ideas as to what the problem is. Link to comment Share on other sites More sharing options...
cruiser647 Posted June 8, 2010 Report Share Posted June 8, 2010 Hi! Welcome to TSN! Does it work with the remote? Other than that, it might be a slight vacuum pipe leak. I think the pump is under the boot lining or thereabouts. Might be worth listening for as you turn the key? Link to comment Share on other sites More sharing options...
IslandeR Posted July 11, 2010 Report Share Posted July 11, 2010 i have a similar problem, if i press the remote button once it unlocks the drivers door and i have to press it again if i want to unlock the passenger door. Link to comment Share on other sites More sharing options...
Cuprabob Posted July 11, 2010 Report Share Posted July 11, 2010 i have a similar problem, if i press the remote button once it unlocks the drivers door and i have to press it again if i want to unlock the passenger door. That's normal operation. It can be reprogrammed using VAG.COM to open all doors and the boot from the first push. Link to comment Share on other sites More sharing options...
