TomoPassat130 Posted June 9, 2010 Report Share Posted June 9, 2010 Hello, I've been thinking about getting my 03 Passat 130 TDI PD re-mapped. I am just wondering if I will need to change the clutch to be able to cope with the extra power or can I keep the standard clutch. If I do have to change will I need a new clutch and flywheel? or just the clutch itself. If anyone could help with this? Thanks Link to comment Share on other sites More sharing options...
shark_90 Posted June 9, 2010 Report Share Posted June 9, 2010 It depends really on the condition of your current clutch, but a good quality remap should be sympathetic on the drivetrain. If you'd like any more info on remaps feel free to ask Link to comment Share on other sites More sharing options...
TomoPassat130 Posted June 9, 2010 Author Report Share Posted June 9, 2010 Ok thanks, the clutch seems fine but I have no idea when it was last changed so that could be a problem :D. Suppose if I get it done and it goes it goes. Life can be cruel. The car is bog standard and with a re-map I have heard I will have to change a whole load of stuff to reap the benifits, such as a new fuel induction system, new exhaust system, air flow, road cam etc etc will I need to do all these? Or will I see a difference without it all. The re-map will make the car 163hp and around 390nm from the standard 130hp and 310nm. I've asked a few people and they say I wont see much of a difference without all these other modifications. Link to comment Share on other sites More sharing options...
paulhardwell Posted August 3, 2010 Report Share Posted August 3, 2010 Ok thanks, the clutch seems fine but I have no idea when it was last changed so that could be a problem :D. Suppose if I get it done and it goes it goes. Life can be cruel.The car is bog standard and with a re-map I have heard I will have to change a whole load of stuff to reap the benifits, such as a new fuel induction system, new exhaust system, air flow, road cam etc etc will I need to do all these? Or will I see a difference without it all. The re-map will make the car 163hp and around 390nm from the standard 130hp and 310nm. I've asked a few people and they say I wont see much of a difference without all these other modifications. im sure shark will say if im wrong as he is a specialist in his field, but when you have a remap, the tuner will change many settings to your specific car, and theres lots of changes they got to do for your cars ecu, b4 it or you will see the benefits, shark has got a good reputation on here and around the country, 2 persons from my family had there vehicles remapped by a so called top tuner, one cars a little bit iffy now and the other wont even turn over, but thats another story when i have all the facts, sorry wondering away from the question, a good tuner will take into consideration about your hole car when tuning it,clutch, drivetrain, lots of things, but please give the car a good test drive b4 you hand over any cash, cheers Link to comment Share on other sites More sharing options...
