garylb1982
please help mk3 gti fault code
1 post in this topic
Hi, i have just joined this forum as i am having a problem with my mk3 golf gti. Basically i had the timing belt changed at the garage. When they did this they could not remove the distributor and when i got it back it would not rev over 5k. I took it back and it had a fault of 00515 camshaft positon (hall) sensor. I bought a new distributor. Still no difference! I have done alot of research on this and it appears to be the timing. I took it back to the garage and they checked the timing and say everything lines up and is fine. They cleared the fault code. I bought myself a vag com and the same fault has reappeared. Does anyone have any ideas as to whats causing this as i am now noticing my car to be hesitating and misfiring. Please help!
