anogg3 Posted July 1, 2010 Report Share Posted July 1, 2010 Hello what difference is there between the turbo on the auy engine and the rest of the tdi engines?? I see the actual turbo has the same part number but only certain ones are or the auy engine... Is there any reason for this or is it just the manifold? What other turbos would fit the sharan engine?? What is the difference between auy and other tdis ??????? Many thanks :grin: Link to comment Share on other sites More sharing options...
vwsteve Posted July 2, 2010 Report Share Posted July 2, 2010 hi there are 2 types of turbo fitted to this engine one for the early mod and one for the later models you can tell the difference by looking at the manifold casting where it bolts to the support bracket on the engine block on the early one the bolt hole runs parallel to the block whereas the later one the bolt hole is facing the engine block to be honest you can fit any as long as you have the right support bracket also if you are looking for a turbo i have one for sale in very good condition if your interested let me know Link to comment Share on other sites More sharing options...
anogg3 Posted July 2, 2010 Author Report Share Posted July 2, 2010 hi there are 2 types of turbo fitted to this engine one for the early mod and one for the later models you can tell the difference by looking at the manifold casting where it bolts to the support bracket on the engine block on the early one the bolt hole runs parallel to the block whereas the later one the bolt hole is facing the engine block to be honest you can fit any as long as you have the right support bracket also if you are looking for a turbo i have one for sale in very good condition if your interested let me know Hello how much do you want for the turbo and which one is it?? Garrett or KKK?? could i have the numbers from it please? Link to comment Share on other sites More sharing options...
vwsteve Posted July 19, 2010 Report Share Posted July 19, 2010 sorry i didnt get back to you sooner but i have been on holiday the turbo is a garret and the no on it is gt1749v 038253019d i would be wanting about £150 for it as it is in good order Link to comment Share on other sites More sharing options...
