jamesR Posted July 23, 2010 Report Share Posted July 23, 2010 Coarse, aggressive, fine, superfine - What's the deal. The clay rolls over the surface and picks up the embedded dirt. Will one clay only pick up the big bits of contaminant whilst another removes the fine debris. In which case should I be using a series of clays? And, whilst I question clays, what prevents the dirt within the clay scratching the painted surface. I like to think of the dirt immediately being sucked up into the clay, and being prevented from touching the paintwork again. But is this the case? Long time since last post, kinda liberating to be out again. Link to comment Share on other sites More sharing options...
eldavo69 Posted July 23, 2010 Report Share Posted July 23, 2010 A fine clay should be suitable for most applications, the more aggressive ones leave make in the paint which require machining out. It will pick up pretty much everything you need it too so no worries there. Sonus green would be a good starting point. With clays you tend to do one section and then refold and reshape the clay, moving the contaminated areas off the exterior surface. Just don't drop it on the floor or else it is only really fit for the bin! Link to comment Share on other sites More sharing options...
