Case Posted August 3, 2010 Report Share Posted August 3, 2010 Hi, I've had a look through the forums but can't find any posts relating to this, so hopefully somebody can help. The slider on the interior vent has become disconnected from the vanes in the back (the vanes which direct the air up/down). It seems to be connected using a little black piece of plastic attached to the back of the bit you move left/right/up/down, which fell out of the vent - so I was hoping I could remove the front to reconnect it. Does anybody know if the front part of the vent (ie. the part which directs the air left/right) can be easily removed? It is on the drivers door side and also the drivers vent in the centre. Any help would be appreciated, as I am sure it is a simple problem! Thanks! Link to comment Share on other sites More sharing options...
Rachel Posted August 4, 2010 Report Share Posted August 4, 2010 lol - happened to me... Friend "adjusted" the vent, and it broke. Mine was fixed under warranty by the OPC - they put in a new vent. To fix it you have to remove the vent assembly. Link to comment Share on other sites More sharing options...
Case Posted August 4, 2010 Author Report Share Posted August 4, 2010 Thanks Rachel, I think it's a trip down the dealership for me! Link to comment Share on other sites More sharing options...
