scooby513v3 Posted September 1, 2010 Report Share Posted September 1, 2010 hi guys ive got a 99 (t) passat vr5 which has gained a water leak ive done a pressure test and found out the leak is at the back of the engine from a housing ????? if anyone has any info on what this is i would be most greatful :) Link to comment Share on other sites More sharing options...
Tipex Posted September 1, 2010 Report Share Posted September 1, 2010 If you do a search on Passat and drain plugs on this (or any VW) forum, you'll find loads of info. Basically, you need to take out the battery and clean out/remove the drain plug under it, and a few others. Link to comment Share on other sites More sharing options...
TIDYDUBS Posted September 26, 2010 Report Share Posted September 26, 2010 See my post under water cowl gives you detailed what to do and prevent further leaks+++ Link to comment Share on other sites More sharing options...
