oleg Posted November 16, 2010 Report Share Posted November 16, 2010 i need help with MMI system on 2005 audi a8 when i turn it on the screen turns on for while and turns of, what might be the problem, i tried it with new controler it still dose the same thing and with new MMI CPU and still had the same problem. What might be the problem, or there somthing else that i did not checked. Link to comment Share on other sites More sharing options...
craigyb Posted November 16, 2010 Report Share Posted November 16, 2010 Anything on the MMI system can cause the problem. You need to get a ring break diagnosis run (optical bus), this may help pin point the problem with a particular module. Either find some one with a genuine VCDS system or ask a dealer to run one for you, although they may charge you. Link to comment Share on other sites More sharing options...
Cockney Boy Posted November 16, 2010 Report Share Posted November 16, 2010 It would help to know where you are too? Link to comment Share on other sites More sharing options...
