rodcar
engine management light on.
4 posts in this topic
Hi all, quick question.
I have an 03 plate tt 1.8 on around 80k and the engine management light has come on but there does'nt seem to be any difference in performance apart from that it seems to be using more fuel than usuall. any ideas??
cheers
Where are you based as there may be a member on here who has VCDS. A simple diagnostic via VCDS will show the fault. It could be something simle like a Lamba or temp sensor.
Had a 52 plate that did just that. Turned out to be a temp sensor.
£60 fitted at dealership.
+1
I agree. Best to run it through VCDS to properly identify and address the issue. It could be the temp sensor but better sure than sorry. +++
