kelshall
2002 passat door not opening
3 posts in this topic
n/s/r door does not open from either inside or out, but button on top of door does go up and down on central locking, any ideas?
Dirt in the lock possible, Mum's Touran did similar, a good whack of the door at lock level while holding the handle did the trick. Then greased it up well.
hi you need a new door lock asap try to get the door open by tapping gently on the door skin below the handle whilst operating the locking
then get the lock unit replaced or otherwise if it packs up in the locked position you will have real probs getting the door open
