uksolly
lossof turbo power
6 posts in this topic
while driving my vw golf gti tdi the other day i put my foot down and the turbo kicked in then i just lost power and white/blue smoke can out of the exhaust and the turbo started to make a fun sound the car run's just with no turbo it sounds as if the turbo wants to kick in but can't plzzzzz help plzzzzzz
Hi! welcome to TSN!
It could be (hopefully) as simple as an air pipe has come loose. Check ALL the air pipes, squeeze and pull them. If they are loose or take an age to reform, replace them.
Good luck!
Is the fun sound like a dead cat is stuck in the engine and is being put through vast amounts of pain?
no not really it sounds like the fan is going but making a wessy sound
thank you i will try that and have agood look at the pipes i do hope the turbo hasn't gone i'd have to make sure i was sitting down when i ask for a price on one lol
Try checking the actual turbo on the inlet side......you will probably find the compressor side mashed or the exhaust side of the turbo gone.What is the age, what mk golf is it? Engine code/BHP please my friend.
Take the downpipe off to the side and inspect,3 12mm nuts or 13mm never can be too sure. From what you describe it is more likely that. See all my other posts relating to turbo issues with VW really will help. Fuel quality and good PD oil make the difference.+++
