Mook Posted March 28, 2011 Report Share Posted March 28, 2011 All teams push the rules as far as they can, in that they "interpret" them. If a rule says "minimum 100mm", that's not too difficult to interpret Link to comment Share on other sites More sharing options...
Cuprabob Posted March 28, 2011 Report Share Posted March 28, 2011 I would have thought if Red Bull had removed KERS they would have to have replaced it with 30kg of ballast otherwise they would be below the minimum weight. I wouldn't have thought any of these designs even with KERS installed were 30kg above the minimum weight. Link to comment Share on other sites More sharing options...
SeanKHotay Posted March 28, 2011 Report Share Posted March 28, 2011 (edited) @Mook: Agreed... ...but I meant it was really picky to put it in the rules (not find someone afoul of it). Why regulate interior wing-to-endplate radii to 100mm? The only thing I can think of is to limit the vortex coming off it. Stupid Overtaking Group recommendations... Edited March 28, 2011 by SeanKHotay Whinging...& Shoulda quoted as I left a space open too long, other traffic came in between Link to comment Share on other sites More sharing options...
Barry Scott Posted March 28, 2011 Report Share Posted March 28, 2011 I would have thought if Red Bull had removed KERS they would have to have replaced it with 30kg of ballast otherwise they would be below the minimum weight. I wouldn't have thought any of these designs even with KERS installed were 30kg above the minimum weight. Good point, didn't think of that! Link to comment Share on other sites More sharing options...
Dblanc Posted March 28, 2011 Report Share Posted March 28, 2011 Of course if you are adding 30kg of ballast you can choose where to stick it rather than where it needs to go in order to fit the KERS system in... Link to comment Share on other sites More sharing options...
Cuprabob Posted March 28, 2011 Report Share Posted March 28, 2011 (edited) Of course if you are adding 30kg of ballast you can choose where to stick it rather than where it needs to go in order to fit the KERS system in... Yes, but if you watched the pre-race interview with Ross Brawn he said as part of the new rules they cannot move ballast about willy nilly as they have to keep the front to rear weight distribution within an agreed tight range. http://www.formula1.com/news/technical/2011/0/828.html Edited March 28, 2011 by Cuprabob Link to comment Share on other sites More sharing options...
SeanKHotay Posted March 28, 2011 Report Share Posted March 28, 2011 Oh, is this what the Sauber disqualification is all about? The Sauber rear wing with illegal part detailed. Credit: @GPU... on Twitpic If so, that's a BS rule. And that's the endplate, not the actual upper wing element. Link to comment Share on other sites More sharing options...
Cuprabob Posted March 28, 2011 Report Share Posted March 28, 2011 Oh, is this what the Sauber disqualification is all about?The Sauber rear wing with illegal part detailed. Credit: @GPU... on Twitpic If so, that's a BS rule. And that's the endplate, not the actual upper wing element. It is pretty tough but even although it's on an end plate that V must be there for some performnce related reason Link to comment Share on other sites More sharing options...
CarMad Posted March 29, 2011 Report Share Posted March 29, 2011 That is not why they are banned. It's the top rear wing element that needs a radii larger that 100mm. It's to stop f-duct type wing stalling to take place when DRS is installed. Sauber had a fault in the manufacturing process that meant it was 5mm out or so they are saying. I think it all got checked out as a result of them being so quick through the speed traps. Maybe if the wing was built correctly it might not have been so quick thus the punishment. Toyota had a similar issue that was found in Qualifying that had them starting from the back of the grid. Link to comment Share on other sites More sharing options...
Scotty Posted April 2, 2011 Report Share Posted April 2, 2011 Looks pretty lacking in rigidity to me ! Axis Of Oversteer: Is Red Bull's front wing flexing again? Link to comment Share on other sites More sharing options...
byron13 Posted April 2, 2011 Report Share Posted April 2, 2011 If the FIA are happy get over it! Link to comment Share on other sites More sharing options...
CarMad Posted April 2, 2011 Report Share Posted April 2, 2011 Yeah they have upped the tests and they still pass so fair play to them. There is nothing stopping the rest copying. Link to comment Share on other sites More sharing options...
